Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1998 Chevy S-10 U Joint...
Auto Repair1996 Nissan Pathfinder ...
Auto Repair1995 Other Jeep Models W...
Auto Repair2002 Other Nissan Models
Auto Repair1995 Nissan Sentra Adju...
Auto Repair2001 Other Jeep Models B...
Auto Repair1997 Ford Ranger Leaky ...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1996 Chevy Cavalier Battery Connections
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Goto page 1, 2, 3  Next
Posted at Tue Jan 15, 2008 11:52 am
By imafishingfred, Have Donated
(13) Give Feedback | Votes: 0
Electrical problem
1996 Chevy Cavalier 4 cyl Front Wheel Drive Automatic 120000 miles
I replaced my battery and accidently connected the cables reverse (+ to - and - to +). I connected the positive and only touched the negative cable for a moment when I realized my mistake. My car started but I had all the warning lights on the dash flashing. I moved the car and parked it. I later tried to start it and it turns over but will not start. I checked the fuses in the engine compartment and all are fine. I do not know how to check the relays in the engine compartment. Any suggestions on what damage I may have done?
Thanks, Fred
Find a car repair manual for your Chevy Cavalier Repair Question.
Posted at Tue Jan 15, 2008 3:48 pm
By BMRFIXIT, Moderator
Reputation: 515.1Reputation: 515.1Reputation: 515.1Reputation: 515.1Reputation: 515.1Reputation: 515.1Reputation: 515.1Reputation: 515.1Reputation: 515.1Reputation: 515.1Reputation: 515.1Reputation: 515.1Reputation: 515.1Reputation: 515.1Reputation: 515.1Reputation: 515.1Reputation: 515.1Reputation: 515.1Reputation: 515.1Reputation: 515.1Reputation: 515.1Reputation: 515.1Reputation: 515.1Reputation: 515.1Reputation: 515.1Reputation: 515.1 (515) Give Feedback | Votes: 18
imafishingfred wrote:
Electrical problem
Thanks, Fred
Check around the starter for fusible links pull lightly on each one to check them
Posted at Mon Mar 10, 2008 2:59 pm
Checked my fusible links (the only one I could find was at the starter), all my fuses are good, but I did notice that the anti-theft light flashes for a long time after the ignition is turned off. If it is flashing the car won't start. Once it stops flashing the car will start. I'm just affraid to head down the road in it for fear it will die in the middle of nowhere.
Posted at Mon Mar 10, 2008 3:07 pm
Turn key on
security light flashing
try to start and let go leave key on
security light flasher for about 10 min
when it stops
turn key off and start car
key needed to be reprogrammed
happy driving after that
in some rear cases you may have to do that 3 times total of 30 min
good luck
Posted at Sat Mar 15, 2008 3:06 am
OK, that worked for the theft light but as soon as I put my car in drive and moved a few feet all the warning lights started coming on and blinking again. Are there other fusible links that I may have missed or do you think I cooked my computer?
Posted at Sat Mar 15, 2008 3:30 am
If it started I would say ECM safe
can you start it back up
check the battery terminals and make sure they are tight
do the key thing again
let it idle for 5 to 10 min
then try driving it
let me know
Posted at Sun Apr 06, 2008 9:26 am
then try driving it
let me know
Took me a while. My primary car died also and it had to be repaired before I could get back to the Cavalier.
I checked the battery terminals. OK
I did the key thing again, 3 times.
I let it idle 5-10 min, 3 times. No lights flashing.
I put it in drive and before I could get out of the driveway the following lights on the dash start flashing or stay on;
brake- on
abs- on
theft- on
airbag- on
seatbelt- on (even when buckled up)
daytime running lights- flashing
check oil- flashing
low water- flashing
battery- flashing
oil pressure- flashing
seatbelt/key/headlight chime goes on and off while driving.
All this starts when put into drive.
Posted at Tue Apr 22, 2008 7:08 pm
By Gtrgilbert541, Have Donated
(7) Give Feedback | Votes: 0
then try driving it
let me know
brake- on
abs- on
theft- on
airbag- on
check oil- flashing
low water- flashing
battery- flashing
Sounds like you might of fried the Engine computer they are usually located behind the dash board, i would consider other options before going and buying new engine computer even though that's what it sounds like they usually cost between $100-$160
Computer
Posted at Mon Oct 06, 2008 8:32 am
then try driving it
let me know
brake- on
abs- on
theft- on
airbag- on
check oil- flashing
low water- flashing
battery- flashing
Computer
Trying to get back to work on this. Checked wiring again and found no problems. Sounds like a computer is next. My repair manual says that the home mechanic cannot install and program the computer and it must be taken to a dealer. Anyone know if this is true? If I have to take it to a dealer, the $100-150 will triple and I don't know if I'm willing to put that kind of money into it.
Posted at Mon Oct 06, 2008 10:19 am
Yes its true you can not replace the PCM with out programming it
it has to go to the dealer
need a tool or a tester CHECK IT @
http://www.2carpros.com/affiliate/uid/bmrfixit_1
need manual CHECK IT @
http://www.2carpros.com/kpages/auto_repair_manuals.htm
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
