Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Question Forum
Auto Repair Questions by Manufacturer
Auto Repair Questions by Topic
Auto Repair First Things to Check
Auto Repair How to Repair or Service
Auto Repair Car Repair Manuals
Auto Repair How Does it Work
Auto Repair Car Repair Video Series
Auto Repair Auto Maintenance
Auto Repair Car Sound Problems
Auto Repair Auto Term Abbreviations
Popular Site Links
Auto Repair Automobile Safety Inspection
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Auto Repair Belt Routing Diagrams
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Trouble Code Table
Auto Repair How to use Diagnostic Tools
Auto Repair Smog Test Preparation
Auto Repair Hybrid Car Information
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1991 Pontiac Grand Prix ...
Auto Repair1996 Dodge Ram Engine D...
Auto Repair2004 Bmw M3
Auto Repair1989 Cadillac Deville P...
Auto Repair1990 Toyota Corolla Intake
Auto Repair1996 Ford Explorer Fuel...
Auto Repair2002 Honda Odyssey Auto...
Auto Repair More Repair Topics...
Car Repair Chat - Ask a Question, Get a Free Answer
BackGo Back RegisterRegister Log inLog in Log in to check your private messagesView your posts ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearch FAQFAQ
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1996 Chevy Blazer Fuel Pump Replacement
Posted at Wed Aug 20, 2008 7:52 am
By fwupow, Likes to hang around!
Give Feedback | Votes: 0
Electrical problem
1996 Chevy Blazer 6 cyl Four Wheel Drive Automatic 116815 miles
Hello Everyone.
I would like to know exactly where the Pulse Dampener / Pulsator is in the fuel delivery system on my 4.3 L V6 CSI, 1996 Chevy Blazer.
Find a car repair manual for your Chevy Blazer Repair Question.
Posted at Wed Aug 20, 2008 2:04 pm
By SWilliams, Loves to solve a problem!
Reputation: 115.8 (116) Give Feedback | Votes: 4
It is located in the tank on the pump module.
Posted at Wed Aug 20, 2008 9:35 pm
I thought that is must be the piece of translucent, ribbed tubing in the pump module, but wasn't sure.
Thanks for providing the clarity.
Posted at Wed Aug 20, 2008 9:58 pm
More fuel pump information. If you own an S10, Astro, Safari, Blazer, Jimmy or Bravada (are there more?), you're probably familiar with fuel pump problems or will be soon.
I dissected my old fuel pump and found surprises. I found that behind one of the two carbon brushes in the electric motor, the metal spring was heavily carbonized, shortened and weakened by apparent overheating. The carbon brush itself was fractured and jammed in it's socket. I'm just guessing, but if the brush couldn't move freely it wouldn't continue to make good contact with the commutator, which would inhibit current flow. Current flow would likley also have been inhibited by all the carbon buildup on the spring, since the current flows from brush to spring to contact to power or ground wire or vice-versa. I've included an image where you can see that the burnt spring (top of picture) is about 2-mm shorter than the good one. Also the burnt carbon brush is in 2 pcs in the photo. It broke apart as soon as I removed it from it's socket in the motor.
SYMPTOMS:
1. Engine cranks fine but won't start. (Easy to confuse with ignition problem).
2. Engine runs fine once started.
3. Hooking up battery charger or jump starting may help get it started.
4. Turning Ign. key On and Off several times may help get it started.
5. Starts fine in warmer weather or soon after it was last running.
6. Won't start in cold weather or after sitting for 24 hours or more.
7. You can hear the pump running and it's quiet and consistent sounding.
8. Fuel pressure test reveals a steady but LOW fuel pressure.
I would expect that no two pumps with a similar failure mode would produce exactly the same symptoms, but if your symptoms are similar, the cause may be the same. You need to hook up a fuel pressure gauge and perform a pressure test and make sure that your problem isn't a bad fuel pressure regulator before replacing the fuel pump.
You can verify fuel pump condition further by performing a current draw test or better yet hooking up a Digital Storage Oscilliscope but I don't know the testing procedures for that off-hand.
NOTE: Fuel pressure should be 60-66 psi on CSI injection systems (VIN# "W" at the 8th digit) and 56-62 psi on SFI injected engines.
P.S. Seems kinda counterintuitive to take a DC motor with sparking brushes and immerse it in gasoline, I mean the gas is pumped right straight through the innards of the motor itself. I guess I'm no physics professor, because I wudda predicted a massive fireball!
Helpful links:
http://www.babcox.com/editorial/us/us30098.htm
http://www.asashop.org/autoinc/jan98/techtotech.htm
http://findarticles.com/p/articles/mi_qa3828/is_200302/ai_n9206860
http://findarticles.com/p/articles/mi_qa3828/is_200303/ai_n9217501
Posted at Sat Aug 23, 2008 9:00 am
No fireball because no air. The mix is to high in fuel to ignite. It is one of the reasons why you use an inert gas when you do EVAP testing. If you used shop air it could make the mix flammable.
The pulse damper is in the housing that the tube you pointed at is attached to. Between the tube and the damper it limits the pulses that the system sees.
Bad brushes and warn commutators are the common failure point.
Oh and those modules can be rebuilt as well. You just need to buy a pump for a 94 S Blazer with the W engine. Then you need to disconnect the tube and crimp it onto the new pump. Then install the pick-up sock.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
More Service Repairs...
Car Question by Model
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Ferrari
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
International
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
MG
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Rover
Saab
Saturn
Scion
Seat
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Home l Help l Privacy Policy l User Agreement l About Us l Computer Repair Question l Contact Us l Link to Us l We're Hiring l Affiliate Program
  Copyright © 1999 - 2009 2CarPros.com - Professional Mechanics Online
