Hi:
If it starts with starting fliuid, then the ignition is working fine. Have you checked for fuel pressure after the fuel pump? Also, if you crank it and it doesn't start, have you checked the spark plugs to see if they are wet with gas?
To me it could be a few different things. First, worn out or dirty fuel injectors, a clogged fuel filter, or just low engine compression.
Let me know the answers to the above listed questions so I can better guide you.
