Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Computer problem
1996 Chevy Blazer 6 cyl Two Wheel Drive Automatic 114000 miles
hello when the blazer sits over nite when you start it the motor runs rough and dies when you get it to run the anti brake light and the brake light comes on and the engine has lost of power then lights will go off and service engine light comes on the codes are po122, p1122 which are egr vavle and trot sens these have been replaced by GM now they say the ecm is bad thats $600.00 from GM can you help me please thanks Sue
P0122= Throttle/pedal position/sensor circuit A low voltage.
P1122=Throttle posistion sensor out of range, or, Ignition control module 4X circuit.
You need to test both the sensors, and the 5 volt reference wire to them, We sell a sensor tester, but some knowledge is needed to use any electrical test equipment. Click on the top link in my sig file.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
