Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Heater problem
1996 Chevy Blazer 6 cyl Four Wheel Drive Automatic ??? miles
My 96 4.3 blew a rod or w/e and we replaced and installed a 97 4.3.. somewhere in the installation process we must have missed hooking up the air controls part? No matter what setting i put my controller on (MAX AC, Defrost, Floor, etc., cold, warm or hot) what actually comes out is Vented Defrost. What do I need to do to make my controls work again?? We suffered without AC over the summer but we NEED heat this winter or the vehicle will be undrivable. I live in northern michigan and vented defrost is not going to thaw my windows! If anyone can help me I'd appreciate it.
Sounds like the vacuum line that goes into the interior is disconnected. Look along the firewall in the engine compartment on the passenger side. There will be a plastic vacuum line that gets connected to a fitting on the engine. The fitting is usually near the distributer area on the engine. It has a T on it that may have been removed and connected directly.
Awesome thanks, we just got back from a trip to town so it's too hot to be sticking my bare hands around back there to find a hose but when it cools down i'll check it out and let you know how it went.
Sorry about the huge delay, I followed the hose from the passenger side over until i found that the vacuum hose was unplugged on the drivers side and plugged it into a hose on the hood.. now it works thanks
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
