Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Transmission problem
1996 Chevy Beretta 6 cyl Front Wheel Drive Automatic
1996 BERETTA WITH 150,000 MILES . THE SPEEDO QUIT AND THE CAR SEEMS TO BE STUCK IN A HIGH GEAR. IS THE TRANNY BAD OR IS THERE A POSSSIBLE BAD SENSOR CAUSING BOTH PROBLEMS AT ONCE?
my guess is the vehicle speed sensor or the wire connector to it has a broken wire. that is causing both your problems. fix it now or you will burn out the transmission.
i belive its located under car on top of trans more toward passengers side and there are 2 wires going to it purple and yellow are the colors of the wires if my memory is correct.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
