Car Repair Advice by Professional Automotive Experts
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1996 Chevy Astro starting
Posted at Fri Nov 20, 2009 5:21 pm |
By
lisa73196,
New to the forum |
Give Feedback | Votes: 0 |
Engine Mechanical problem
1996 Chevy Astro 6 cyl All Wheel Drive Automatic 110000 miles
one day my van starts right up and the next it just cranks. I put in a new battery and a new starter and it was great for 2 days. Now it just cranks but won't start. After 2 days of it just cranking it started right up on the third day. Why is it doing this? and how do I fix it?
Thanks |
Find a
car repair manual for your Chevy Astro Repair Question.
Posted at Fri Nov 27, 2009 11:30 am |
By
1dodge2,
Likes to hang around! |
(23) Give Feedback | Votes: 0 |
Welcome to 2CarPros, Need a little more info, is the check engine light on? If so, knowing what code or codes are stored would be helpful. On the days when the engine turns over but will not start, check for spark and fuel delivery. With the dog house, (engine cover), removed, You will need to disconnect a fuel injector electrical connector and install a noid light to check for injector pulse. |
Find a
Posted at Mon Nov 30, 2009 7:00 pm |
By
mickey-d,
Loves to help! |
(70) Give Feedback | Votes: 2 |
It might be a good idea to check the electrical ignition switch that is located on the steering column. Sometimes when the key switch returns to the run position, the rod that controls the switch does not pull back far enough to engage the run side. The switch is usually black and is hooked on with two 5/16 or
8mm screws, its about 3" long, and will have
a flat wire harness with several wires in it plugged into the switch. Good luck, hope ot works mickey-d |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
