Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Air Conditioning problem
1996 Cadillac STS V8 Two Wheel Drive Automatic 60,000 miles
I have a 1996 Cadillac STS, Blower motor is bad, I have removed the bolts holding the motor to the housing and is loose but not enough room to remove the blower motor and wheel as an assembly, Is it necessary to cut out and relplace the housing or couling?
the cars motor needs tilted forward, remove the front cradle bolts and jack the car up and put jack stands at the drivers and passanger door, A pillar, and then let down on the jack, this will tilt the motor forward enough to get it out or ( I never done this but ) remove the valve cover?
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
