Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1999 Ford F150 Speed Se...
Auto Repair1997 Toyota Corolla Tim...
Auto Repair1997 Other Jeep Models I...
Auto Repair1996 Chevy Silverado Fu...
Auto Repair1998 Chevy Truck Starting
Auto Repair2002 Ford Focus Engine ...
Auto Repair2005 Other Jeep Models
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1996 Cadillac SRX - STS Programming Remote Keyless Entry
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Thu May 01, 2008 9:26 pm
By kimberlywilliams, New to the forum
Give Feedback | Votes: 0
Electrical problem
1996 Cadillac SRX - STS V8 180,00 miles
Hi. I am trying to program one keyless entry fob..this is the directions I am follwing....With the ignition in the "RUN" position (engine does not necessarily need to be running, but it will work either way).
Press OFF and WARMER (or the OFF and PASSENGER WARMER buttons) on climate control panel simultaneously. Instrument Panel Cluster (IPC) will light all telltales, then go blank. System is now in DIAGNOSTIC MODE. After diagnostic mode cycles through and stops, press FAN DOWN button until "RFA?" is displayed, then press FAN UP. If "RFA DATA?" is displayed, press FAN DOWN. If "RFA OVERRIDE?" is displayed press FAN UP button.
If "RFA S00 NO OVERRIDE" is displayed, press FAN DOWN. If "RFA S01 PROGRAM FOB #1" is displayed, press FAN UP button.
IPC will show "0" on right side of Drivers Information Center (DIC) display. Press WARMER button on the climate control unit until "99" is displayed.
Press and hold TRUNK button on the transmitter. While holding TRUNK button, press LOCK button and hold both buttons for a total of 3 seconds. Locks will cycle when programming is complete. If transmitter is not programmed within 30 seconds after entering "99" on the display, system will default and you must begin at step #2 again.
To program second transmitter, press FAN DOWN button until "RF S02 PROGRAM FOB #2" is displayed, then press FAN UP. Repeat step #4.
To exit system, press AUTO, MODE UP, MODE DOWN, or RESET button.
After it goes through the diagnostic cycle it will stay constant on PCM? No matter how long I hold the fan down button it won't go to the next step...since I am new at this I had to try it several times and I did get it to where I have to get it to the "99" but hit the wrong button and had to start over...now I can't seem to get past the PCM? part....what do I do? And I have only one fob and it is fob #2, does that make a difference and if so how do I program just the 2nd fob? My car is a STS. Thankyou in advance
P.S. I don't have a warmer button, I have a temp knob for the driver side of the climate control and a up/dwn for the pasenger ...does that make a difference...and do I turn the knob until the "99" shows or use the passenger temp thing?
Find a car repair manual for your Cadillac STS Repair Question.
Posted at Mon May 05, 2008 2:39 pm
By Buzzsaw, Moderator
Reputation: 216.4Reputation: 216.4Reputation: 216.4Reputation: 216.4Reputation: 216.4Reputation: 216.4Reputation: 216.4Reputation: 216.4Reputation: 216.4Reputation: 216.4Reputation: 216.4 (216) Give Feedback | Votes: 13
kimberlywilliams wrote:
Electrical problem
push down on the mode button or go to the dealer and have it programed through the tech 2
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
