Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Electrical problem
1996 Cadillac Deville V8 Front Wheel Drive Automatic 138000 miles
While driving at night, when I apply the brakes, the headlights dim out for a short bit. Also, when coming to a stop sign, sometimes the headlights dim out considerably. Also, even while driving, at times the headlights flicker. Do I have a bad battery or an electical short or what?
First to better assist you, is your Cadillac just a Deville or Deville Concours? Also it is a 4.6L engine and the 8th digit of your VIN is a Y?
Please go to Auto Zone (AZ) or O’Reilly’s (OR)and for FREE they can pull the codes to the car. Most important: Once they check your codes, if they find something and you don’t get it fixed and need to get back with us, please make sure you tell us exactly what the code was, number and all. Example, if the code was E0568 O2 Sensor bad. Then make sure you give us all of that. While there for FREE also they can bring their tester out and check your battery, alternator and starter.
Please provide the info above and the results from AZ or OR and we can take it from there.
Thanks for the donation
Please let us know if what the final fix was for your car so we can better assist others. Thanks!
Find a car repair manual for your car repair questions.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
