Hi bssaunders,
The check light means something is wrong with the engine management system.
You need to get the problem solved to turn the check light off. Get a scan done to find out what the ECU is trying to tell you.
You need to remove the inner cover which is plugged in with plastic clips. Pry it off with a screw driver. You would see screws below and from there you would be able to progress.
