i'm not sure how much you know about your car, but it only comes with adjustable toe. with your mileage, i doubt that the other angles are perfect.
the condition of your struts, tie rods and arms would be easier to find out if you can read the alignment.
uneven tire wear and inflation can cause a pull even if alignment is perfect.sometimes even tire brands do that.
adding aftermarket parts like camber kits, sway bars etc will improve handling/response.
steering effort only has few causes, if the ps pump and the ps rack are fine, check the belt or pulley.
btw, you can drift the integra without using the e-brake.just use brake pedal timing and steering/throttle control.
