Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Manual Ask a Car Repair Question
Auto Repair Manual Car Questions by Manufacturer
Auto Repair Talk Auto Questions by Topic
Vehicle Repair Car Repair Forum
Auto Repair Talk Car Repair Troubleshooting
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Video Series
Vehicle Repair How to Use Test Equipment
Auto Repair Manual Car Maintenance Information
Vehicle Repair Service Engine Soon Light
Vehicle Repair Car Parts and Equipment Store
Vehicle Repair How Does it Work?
Vehicle Repair Safety Inspection
Auto Repair Manual Online Car Repair Manual
Vehicle Repair Smog Test Preparation
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair2001 Bmw X5 Intrument C...
Auto Repair1997 Chevy Lumina Tire ...
Auto Repair1997 Chevy Monte Carlo ...
Auto Repair2000 Mazda Protege Brok...
Auto Repair1994 Jeep Cherokee Clutch
Auto Repair2007 Chevy Monte Carlo ...
Auto Repair2005 Chevy Lumina Hi
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Car Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1995 Toyota Tercel Idle problem
Welcome to our question and answer forum where over 6,000 free auto repair questions are answered every month, after you have completed our free signup you will able to ask a question and receive an answer from one of our many forum members.
If you elect to donate any small amount of money we will assign one of our 2CarPros Certified Repair Technicians to answer your question. Questions with donations are answered promptly and 100% of the donation is awarded to the technician helping you.
New Watch our new Car Repair Video Series with Ken Lavacot.
Goto page 1, 2  Next
Posted at Wed Jul 02, 2008 7:35 pm
By sless, Likes cars!
Give Feedback | Votes: 0
1995 Toyota Tercel
I have this 95 Tercel with quite some mileage but was running perfectly before ... this!! First I thought rain / humidity didn't help but same problem after 2 hot sunny days. I need to hit the gas pedal once or twice to get the motor going. Idle the motor just dies but If accelerating the motor runs fine but you can smell the gas burning up and a smoke build out the exhaust.
I was told the Oxygen Sensor was defective which I plan to replace but any other ideas? The car was parked for 2-3 months, was running fine before but now this problem is persistent.
Find diagnostic tools, replacement parts or locate a car repair manual for your Toyota Tercel Repair Question.
By Advertisment,
Posted at Wed Jul 02, 2008 7:49 pm
By legitimate007, Moderator
Reputation: 142.4Reputation: 142.4Reputation: 142.4Reputation: 142.4Reputation: 142.4Reputation: 142.4Reputation: 142.4 (142) Give Feedback | Votes: 6
I would check the fuel pressure regulator and also check the idle air control valve. amongst other small things like pcv valve,and air filter/breather.
Posted at Wed Jul 02, 2008 7:50 pm
Posted at Thu Jul 03, 2008 4:57 am
Does the Os2 sensor have anything to do with it?? It was brought to a mechanic before it got parked and the mechanic confirmed an Os2 was needed. The lady didnt mind fixing it and bought a new car.
Weird thing is that I went one mornning and test drive the car, everything was fine ... went back during the evening to pick it up and the car was running bad on idle and burning gas
Posted at Thu Jul 03, 2008 5:29 am
Also, would a basic tune up help? Plugs, cables etc ...
Posted at Thu Jul 03, 2008 11:21 am
well a o2 could have a lot to do with it it is the sensor that tells the computer if your running rich or lean, also it helps determine operating temperature
Posted at Fri Jul 04, 2008 8:18 am
OK so here's an update. Testing many things like changing plugs, wires etc ... disconnected the exhaust from the motor to see if the catalytic was blocked and none of that worked.
When I disconnected the PCV Valve the motor started to run perfectly ... does that mean the valve is defective or is it a sign that something else is defective elsewhere?
But ... there's always a BUT right? PCV valve disconnected, motor runs fine but there's a big cloud of white smoke ... Head gasket? What's involved in changing a head gasket?
Posted at Fri Jul 04, 2008 10:46 am
change that pcv its no good, and yeah it could mean a bad gasket because of the white smoke. that clogged pcv could have cause whatever vacuum or oil leaks you have (if any) right now . because its use to release gas build up and if its clogged it cant be released and will try to find the weakest way it can to release itself, and that usually is one of the gaskets. change the pcv and air filter(if dirty) and let me know what happens with the smoke
Posted at Fri Jul 04, 2008 10:48 am
will do ... that PCV valve alone won't fix the white smoke will it??
will update shortly - this site is really amazing
Posted at Fri Jul 04, 2008 10:54 am
theres a slight possibility, only because its been blocked for so long, it may be getting rid of condensation, lets hope for the best.
Goto page 1, 2  Next
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
