Car Repair Talk - Ask a Question, Get a Free Answer
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1995 Toyota Camry Vibrations felt on steering wheel when ca
Posted at Mon Jun 01, 2009 7:15 pm |
By
yocar,
Likes to hang around! |
Give Feedback | Votes: 0 |
Steering problem
1995 Toyota Camry 4 cyl Two Wheel Drive Automatic 148K miles
I have no problems when car is running and brakes are applied, however have a unique scenario that when the car is not in motion (say waiting at the intersection lights) and brakes have been applied, I feel vibrations on the steering wheel.
When I change the gear stick from D(Drive) to N (Neutral) the vibrations fade out considerately.
Please help me to figure out if this is anything to do with CV joint/axle, mounts etc etc. I have take to couple of mechanics and they haven't been able to figure out. |
Find a
car repair manual for your Toyota Camry Repair Question.
Posted at Sat Jun 06, 2009 7:26 am |
By
KHLow2008,
Certified 2CarPros Technician |
                               (3196) Give Feedback | Votes: 48 |
Hi yocar,
The engine mount conditions are not good causing the vibration. |
Find a
Posted at Tue Jun 23, 2009 6:41 pm |
By
yocar,
Thanks for your response.
I had already replaced the front engine mount (twice) and the engine torque mount, but still have the same problem.
Do you have any other advice? |
Find a
Posted at Wed Jun 24, 2009 5:12 am |
By
KHLow2008,
When in forward gears, the rear engine mount is the one that is being stressed.
Is the vibration the same when reverse is engaged? |
Find a
Posted at Fri Jul 03, 2009 9:29 pm |
By
yocar,
No, I do not feel the vibrations when the gear is in reverse and the car is standstill.
May be as you mentioned the rear engine mount could be the one.
Do you think it will be costly to get the rear engine mount checked? (I mean can the mechanic check this without taking the engine out?) |
Find a
Posted at Sat Jul 04, 2009 3:36 am |
By
KHLow2008,
A simple way to check the rear mount is to watch the engine while someone engages reverse with engine running and brakes applied.
If the engine moves forward with a jerking motion and the movement is more than an inch, the mount should be bad. Be sure to check the upper torque rod position first. Disconnecting it would make the engine movement easier to detect. |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
