Car Repair Forum - Ask a Question, Get a FREE Answer.
Go Back
1995 Toyota Camry Engine hesistates upon acceleration after
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Posted at Thu Jul 24, 2008 11:21 am |
By
jsbryner,
Likes cars! |
Give Feedback | Votes: 0 |
Engine Performance problem
1995 Toyota Camry 4 cyl Front Wheel Drive Automatic 156000 miles
I have a 1995 Camry that hesitates (almost dies) upon acceleration immediately after a cold start. Once the car is warm the hesitation is almost non-apparent although not quite as peppy, especially upon acceleration up an incline. I have replaced the fuel filter, but it did not solve the problem. Any help/suggestions would be much appreciated.
| Find a
car repair manual for your Toyota Camry Repair Question. |
By
Advertisment,
| Find a
Posted at Wed Jul 30, 2008 1:02 pm |
By
jsbryner,
Likes cars! |
| rasmataz wrote: | | Check the fuel pressure, mass airflow and throttle position sensors. |
The fuel pressures are good, this vehicle does not have a mass airflow, and I have cleaned the intake side of the throttle body (butterfly valve and opening to hose). The spark plugs were replaced as well as new wires. Any other ideas?
| Find a
Posted at Thu Jul 31, 2008 8:16 am |
By
jsbryner,
Likes cars! |
| rasmataz wrote: | | Did you test the throttle postiion sensor closed and WOT voltages could be out of range? |
I have not checked yet. Another thought, would a worn valve guide effect the car this way? It does have a little rough idle that improves upon increasing RPMs, but I only notice the hesitation when the car is in drive. If it is in park, I can press on the accelerator without any hesistation (even upon cold start)
| Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
