Engine Mechanical problem
1995 Pontiac Grand Prix 6 cyl Two Wheel Drive Automatic 135,00 miles
I have a Pontiac Grand Prix, one day I was driving to work then all the sudden, the engine bogged down and all the lights started flickering. I tried to give it gas but it contiued to shake and slow down. It cranked up one time right after and that was it. At first I thought it was the alternator but I took it and had it tested and it was fine. I then changed the spark plugs and wires and this didnt help. I changed the fuel filter and still nothing. When I try to crank it sounds like its not firing and it is draining the battery. It is still getting fuel to the engine cause fuel is coming out when I push in the pin on the block. Please help if you have any more suggestions I would appreciate it.
