Professional Mechanics Online Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Car Repair Home
Auto Repair Manual Auto Repair by Topic
Auto Repair Manual Auto Repair by Manufacturer
Auto Repair Talk Ask a Car Repair Question
Vehicle Repair Online Repair Manual
Auto Repair Talk Car Repair Forum
Vehicle Repair How to Repair & Service
Vehicle Repair Car Repair Troubleshooting
Vehicle Repair Car Repair Video Series
Auto Repair Manual How Does it Work
Vehicle Repair Avoid Car Repair Rip Off
Vehicle Repair Car Maintenance
Vehicle Repair Car Safety Information
Vehicle Repair Smog Test
Auto Repair Manual Diagnostic Trouble Code
Vehicle Repair Engine Code Scanner
Vehicle Repair Discount Auto Parts
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviation
Search Website
Recent Forum Topics
Auto Repair1987 Chevy S-10 Engine Swap
Auto Repair1997 Ford F350 Vehicle I...
Auto Repair1998 Ford Mustang Engine...
Auto Repair1998 Toyota Camry Oil Leak
Auto Repair1998 Chrysler Town And Co...
Auto Repair1996 Chevy Cavalier Spee...
Auto Repair1997 Dodge Caravan
Auto Repair1999 Ford Taurus Tranmis...
Auto Repair1997 Chrysler Town And Co...
Auto Repair2003 Chevy Impala Diagra...
Auto Repair2000 Honda Accord Batter...
Auto Repair1991 Toyota Camry Free P...
Auto Repair1998 Gmc Jimmy
Auto Repair2003 Chevy Astro Ac Not ...
Auto Repair2005 Pontiac G6 Wheel Be...
Auto RepairMore Forum Topics...
Locate Auto Parts
Latest How-To Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Automotive Repair Forum
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1995 Pontiac Grand Am OVER HEATING
Posted at Wed Mar 26, 2008 11:37 pm
By SAMS4BOYS, New to the forum
Give Feedback | Votes: 0
Engine Cooling problem
1995 Pontiac Grand Am 4 cyl Front Wheel Drive Automatic 17000 miles
I HAVE BEEN OVERHEATING FOR AWHILE I CHANGED THE WATERPUMP THE THERMOSTAT THE HEATERCORE THE HOSES THE RADIATOR MY COOLANT ISNT BROWN NOTHING IS MIXED AND IM NOT SURE NOW WHAT TO DO THE ONLY THING I CAN THINK OF IS I HAVE A BLOWN INTAKE THE FAN IS ALSO NEW NEW ALTENATOR AND MY SMOKE FROM THE CAR IS NOT BLACK OR BLUE SO I DONT KNOW PLEASE HELP...
Find a repair manual for your Pontiac Grand Am Repair Question.
Posted at Thu Mar 27, 2008 3:23 am
By rasmataz, Certified 2CarPros Master Technician
Reputation: 664.8Reputation: 664.8Reputation: 664.8Reputation: 664.8Reputation: 664.8Reputation: 664.8Reputation: 664.8Reputation: 664.8Reputation: 664.8Reputation: 664.8Reputation: 664.8Reputation: 664.8Reputation: 664.8Reputation: 664.8Reputation: 664.8Reputation: 664.8Reputation: 664.8Reputation: 664.8Reputation: 664.8Reputation: 664.8Reputation: 664.8Reputation: 664.8Reputation: 664.8Reputation: 664.8Reputation: 664.8Reputation: 664.8Reputation: 664.8Reputation: 664.8Reputation: 664.8Reputation: 664.8Reputation: 664.8Reputation: 664.8Reputation: 664.8 (665) Give Feedback | Votes: 63
Try bleeding the cooling system don't work do the the block and pressure tests
Always bleed air from cooling system after replacing coolant. Set heater for maximum heat. Remove radiator cap. Loosen drain plug and remove drain bolt (if equipped) from engine block. Drain coolant reservoir. Fill coolant reservoir to MAX mark with 50/50 water-coolant mixture. Loosen bleed bolt and fill radiator up to base of filler neck. Close bleed bolt when coolant flows out without bubbles. Tighten bleed bolt. With radiator cap removed, start and operate engine to normal operating temperature. Add coolant if necessary and check for leaks.
Have it block and pressure tested-do the block first to pinpoint a combustion leaking into the cooling system or a gas analyzer to sniff for hydrocarbons at the radiator fill neck.
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
If the block and pressure test passes check the following: Thermostat,Pressure test the Rad. cap,Clogged radiator,Fan clutch,Radiator electrical fan,collaspe hoses,water pump
Make a small donation! (We will make sure your question will be answered promptly)
Reply to topic
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins.Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Popular Question Topics
Alternator
Starter
Exhaust System
Fuel Economy
Rough Idle
Won't Start
Water Pump
Fuel Filter
Battery
Car Alarm
Multi Rib Belt
Catalytic Converter
Head Gasket
Intake Manifold
Motor Oil
Antenna
Air Bag
Fuel Pump
Seat Belts
Heater Core
Air Conditioner
Transmission
CV Axle Joint
Clutch
ABS
Front Brakes
Brake Rotor
Suspension
Oxygen Sensor
Mass Air Flow Sensor
Spark Plugs
Fuel Injector
Check Engine Light
EGR Valve
More Topics...
Popular Manufacturers
ACURA
ASTON MARTIN
AUDI
BMW
BUICK
CADILLAC
CHEVY
CHRYSLER
DODGE
FORD
HONDA
HYUNDAI
ISUZU
JAGUAR
JEEP
LAND ROVER
LINCOLN
MAZDA
MERCEDES BENZ
MERCURY
MITSUBISHI
NISSAN
OLDSMOBILE
PLYMOUTH
PONTIAC
PORSCHE
RENAULT
SAAB
SATURN
SUBARU
SUZUKI
TOYOTA
VOLKSWAGEN
VOLVO
More Manufacturers...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
Computer Repair
