Logo Automobile Information Add to Favorites  Automobile InformationLogin  Automobile InformationSign Up
Auto Repair
Auto Repair Home
Auto Repair Questions by Manufacturer
Auto Repair Questions by Topic
Auto Repair Ask a Car Repair Question
Auto Repair Car Question Forum
Auto Repair First Things to Check
Auto Repair How to Repair or Service
Auto Repair How Does it Work
Auto Repair Automobile Safety Inspection
Auto Repair Car Repair Video Series
Auto Repair Auto Maintenance
Auto Repair Car Sound Problems
Auto Repair Auto Term Abbreviations
Popular Site Links
Auto Repair Car Repair Manuals
Auto Repair Brake Replacement Guides
Auto Repair Tips Car Owners Should Know
Auto Repair Service Engine Soon Light
Auto Repair Belt Routing Diagrams
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Trouble Code Definitions
Auto Repair How to use Diagnostic Tools
Auto Repair Smog Test Preparation
Auto Repair Hybrid Car Information
Recent Repair Topics
Auto Repair1986 Mercedes Benz 190e ...
Auto Repair1999 Jeep Cherokee Subz...
Auto Repair2001 Volkswagen Jetta P...
Auto Repair1989 Jeep Cherokee Fan ...
Auto Repair1998 Pontiac Sunfire Lo...
Auto Repair2003 Volvo V70 Stalling...
Auto Repair1967 Ford Mustang After...
Auto Repair More Repair Topics...
Professional Automotive Experts Answering Your Questions
BackGo Back RegisterRegister Log inLog in Log in to check your private messagesView your posts ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearch FAQFAQ
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1995 Plymouth Voyager no spark
Posted at Fri Oct 16, 2009 1:24 pm
By triviaman, Likes to hang around!
(8) Give Feedback | Votes: 0
Electrical problem
1995 Plymouth Voyager 6 cyl Front Wheel Drive Automatic
There's no spark to the plugs.I've tried ignition control module and coil pack. What else could be the problem?
Find a car repair manual for your Plymouth Voyager Repair Question.
Posted at Sat Oct 17, 2009 12:07 pm
By ch112063, Problem solver!
(67) Give Feedback | Votes: 13
You say no spark out of coil when you pull plug wire, crank, and hold near ground?
Well is it 3.3, 3.8L. Or 3.0. If 3.3 or 3.8L the relay juices the coil, and the fuel pump. Is there a main engine power fuse out in the power distribution center under the hood? nOT JUST A BIG FUSE, ANY SMALL,MINI, or fuse link out? That powers up the PCM which is the ignition control module. Use a 12volt test light, clamp its wire to ground, and probe for power on each side of the fuses and fuse links. If no fuse links then all fuses. OK
Posted at Mon Oct 19, 2009 1:51 pm
I know the fuses are good, but will try your suggestion. Thanks for the response.
Posted at Mon Oct 19, 2009 4:47 pm
Glad to help. The good thing about the voltage probe is its fast and accurate testing of the power to the computer for all of the computers. Even fuse link wires can be checked quickly on both sides. I hope you get it started.
Posted at Fri Oct 23, 2009 9:59 am
Hope this is the last question. Checked the fuses, and fuse links with light tester, everything appears to be working. Battery is good, fuses are good, changed control module and coil pack. What else could be the problem? Is there a way to bench test module and pack to be sure?
Thanks again
Posted at Fri Oct 23, 2009 2:35 pm
You have told me that there is no spark. And no fuel, or you smell gas?
Wonderful, I'm happy. You,ve replaced the black computer called a PCM.
And coil pack with all three coils, so take a scan reading. Get in, turn key on,off,on,off,on and look at the check engine lamp. It'll blink if the PCM is OK.
Write these blinking codes down. The last code is 5 blinks and 5 blinks. code 55, the end of self diagnostics. You may have a code 12 first, after this let me know.
You have a 3.3 or 3.8. Or 3.0L? You have a 12 volt test light? You have all good fuses? Battery is good? Crank it over and read the codes, after cranking with all things hooked up. You smell gas? You hear relays and fuel pump after turning key on?
The key test should be done all within 5 seconds and you can do it over and over so take your time, and tell me what codes, if any. No to bench test of module. Both are tested in vehicle. A test is available, since you have done the things I asked, we are starting.
There is a crank sensor and cam sensor. A shutdown relay, a fuel pump relay, and a timing belt we must check, so we'll start with codes. OK Need info on size of engine and gas smell.
Its fuel, spark, and engine. So answer the questions, the more I know, the better and faster it goes. There may be more questions, but with a new voltage tester(thank-you) and answers, I'll see you as far as we can, ok. I'll check back at 8:00
Or tomorrow so don't rush. As lomg as the parts are good and they have power at their wiring, not much left. So test for power to the comp. and coil pack wires, if you can after you give me the codes and engine and gas check. No belt with 3.3, 3.8. Just crank and cam and PCM, coils and wires to plugs. I'm glad to help T man.
Posted at Sat Nov 07, 2009 2:42 pm
I feel the need to apologize for wasting your time. After reading back our posts several times I realized that we had a miscommunication going. When I was talking about the ignition control module and you were talking about the PCM I thought we were talking about the same thing. There is a powertrain control module on my vehicle and that is what I realized you meant by PCM. I now believe that that is the part that is out.
Thanks for all your help and I'm sorry for the time wasted.
Posted at Sat Nov 07, 2009 6:11 pm
The powertrain control module is the coil driver, but it must first be turned on by the key(fused, in power center, under hood fuse box, not inside interior fuse box) if PCM gets turned on, then it will look for an engine cranking signal from the crank sensor or distributor and then it will start to control the coil. That is why I needed the engine size and to let you know that it must have power and a sense that the engine is cranking, or no coil activation. 3.3,3.8L it could be a bad crank sensor, these are the most common. But the PCM does fail. Rarely though. It is inside of poured gel. The codes that a scanner(small diagnostic screen) tells the technician helps to get to a starting point so all else can be ruled out before replacing a part that a customer or Chrysler must pay for. If it is wrong, the technician pays, so we do not make same mistake twice. Coil pack? Means your dealing with a 3.3L. I'll check something now. You are not wasting my time. Your van is wasting your time.
Ok, I am back. And UCONN is losing to CINCY. HMMM.
In car fuse number 16 is a 10amp, if your check engine light is on, that should be ok.
Then check two 15amp fuses in the power center fuse box(black with lid) in the engine compartment. One will say engine and the other will say fuel pump.
And one more inside number 3, 20 amp.
The 10 amp fuses are red, 15 are blue and 20 are yellow.
If you have good fuses then see if the large fuses in that power center are ok, they're big plastic ones. Then the codes are checked, the wiring(circuits are tested for continuity(see if they aren't broken) and grounds are checked, if no codes then the PCM goes. You've replaced coil pack, maybe the PCM is not getting a crank sense, or cam, or MAP, they all will cause problems but the cranksensor causes no spark from the coil most of the time, as long as the engine is turning the trans. The crank sensor mounts in the top part of transaxle a little towards the rear. Make sure it is plugged in.
Either you understood me or no, I do hope this beast starts so you can go back to your life and start it and turn the heat on. lol. OK
Posted at Mon Nov 23, 2009 3:05 pm
after a month of trying, money spent on parts (to be returned when they were not the problem) and about 10 mins. from calling a salvage yard it turned out it was a 30 second fix. We checked all the parts and fuses under the hood and all came up good. What we didn't check were the fuses under the dash (didn't think there'd be fuses under there dealing with ignition).
We were wrong, checked the "ignition feed" fuse and it was blown, replaced it and started right up.
Thanks for all your help.
Triviaman
Posted at Mon Nov 23, 2009 6:05 pm
I looked at the date because I had forgotton about your van. I am happy you answered with good news, I would keep a box on hand. Especially now, that you have a reliable way to make sure there is voltage to the fuse, as even a good fuse, only means a good fuse, not a complete circuit. A good ending. and a handy 12 volt test light. Good for many future problems.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
Test Fuses
More Service Repairs...
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Ferrari
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
International
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
MG
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Rover
Saab
Saturn
Scion
Seat
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Advertise 2Carpros.com
Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l We're Hiring
Copyright © 1999 - 2010 2CarPros.com - Professional Mechanics Online
