Auto Repair Talk - Ask a Question, Get a FREE Answer.
Go Back
1995 Other Oldsmobile Models 1995 Delta 88, random engine st
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Posted at Tue Jun 03, 2008 10:12 am |
By
MDJLT,
Likes cars! |
Give Feedback | Votes: 0 |
Engine Performance problem
1995 Other Oldsmobile Models 6 cyl Two Wheel Drive Automatic 115000 miles
I have replaced spark plugs, wires, spark coils, and had engine checked out by local dealer. Car will be running fine for weks at a time then will randomly stall when driving, no indication of issue prior to stalling. Runs good, smoth idle, good acceleration, no issues we can find. When driving car has stalled at low speed 20mph and at highway speed 65mph. Their is no indication anything is wrong prior to stall, just suddendle the engines off, all electrical still works, just no engine. When this occurs I just put the car in neutral, keep coasting with traffic, and restarts immediately, back into drive and keep going. Has happened 3 times in last 3 months and about 6 times in the last year. I have no clue, and aparently neither does the dealer. any suggesstions??
| Find a
car repair manual for your Other Oldsmobile Models. |
By
Advertisment,
| Find a
Posted at Wed Jun 04, 2008 3:50 pm |
By
Mike Frech,
New to the forum |
I have exactly the same problem with my daughter's 1995 Delta 88 LSS and have tried many of the same fixes. From her description (which is rough at best), it acts like it is temporarily starved for fuel. I'm thinking fuel pump? Not sure. This time I think it threw a code, which I need to pull.
details of the car:
Supercharged 3.8L 67,000 miles
New plugs, wires, harmonic balancer (the rubber dry-rotted). No major repairs otherwise. Problem occurs about once / month --- stalls for no reason, starts right up afterwards. Originally suspected loose battery terminals / ignition loosing power. Have tightened battery cables, "seems" to work for a month or so.
| Find a
Posted at Fri Jun 27, 2008 6:08 am |
By
MDJLT,
Likes cars! |
Had the problem happen again the other day. I had just filled the gas tank and shortly after the engine just stopped again and immediately restarted. It almost seamed that a slug of water went through the system. I wonder if their is a possibility that moisture collects in a location until it reaches a certain level then gets sucked through the fuel line all at once and kills the engine. In thinking back I do not believe I have ever had the engine die during the winter or cold season. Any thoughts? is their some place in the tank or the fuel system where water could accumlate until it got high enough to suddenly be fed into the injectors??
| Find a
Posted at Wed Aug 13, 2008 10:11 am |
By
MDJLT,
Likes cars! |
Borrowed a code reader, no codes stored in the car...Sigh.........
| Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
