Professional Mechanics Online Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Car Repair Home
Auto Repair Manual Auto Repair by Topic
Auto Repair Manual Auto Repair by Manufacturer
Auto Repair Talk Ask a Car Repair Question
Vehicle Repair Car Repair Video Series
Auto Repair Talk Car Repair Forum
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Troubleshooting
Vehicle Repair How Does it Work?
Auto Repair Manual Car Maintenance
Vehicle Repair Online Repair Manual
Vehicle Repair Discount Auto Parts
Vehicle Repair Car Safety Inspection
Vehicle Repair Smog Test
Auto Repair Manual Diagnostic Trouble Codes
Vehicle Repair Engine Code Scanner
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair1998 Lincoln Navigator S...
Auto Repair1997 Nissan Altima Repla...
Auto Repair1966 Ford Mustang 1966 F...
Auto Repair1991 Ford F150
Auto Repair2003 Chevy S-10 2003 Zr2...
Auto Repair1997 Ford Mustang Got On...
Auto Repair1991 Ford Explorer Calipers
Auto Repair1995 Buick Riviera 1995 ...
Auto Repair2006 Hyundai Accent Rear...
Auto Repair1997 Ford F150 Oil Filter
Auto Repair1995 Chevy Lumina New Ra...
Auto Repair2001 Mercedes Benz S500 ...
Auto Repair1995 Honda Accord Junk M...
Auto Repair1998 Jeep Cherokee Belt ...
Auto Repair2002 Saturn L200 Trunk R...
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Auto Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1995 Nissan Sentra rev/rpm limiter
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Mon May 12, 2008 7:26 pm
By quenncy, Have Donated
Give Feedback | Votes: 0
Engine Mechanical problem
1995 Nissan Sentra 4 cyl Front Wheel Drive Manual 200000 miles
I am a shade tree mechanic but this problem has me baffled. My wife comes home the other day and says when she left work the car barely wanted to crank over so I am thinking it’s the battery since I replaced the alternator 2 years prior. I get my volt meter out and check the batter and sure enough 11.75 volts then I start the car and it the same 11.75 voltage so I go to check my alternator and notice it’s belt was gone so I replaced the belt which connects the Alternator, A/C Compressor & Crank then start the car and now I am getting 13.5 volts which is great but now a new problem as emerged. At an idle (aprox. 800 rpm’s) there is no trouble and the car idles fine but if you try to give it the least amount of gas (around 1500 rpm’s or above) the car rages up and down on its RPM'S when you are keeping the accelerator constant, sounds like the rev/rpm limiter is kicking in why to early. Check the fuel supply and its PSI is constant and accurate. There is no codes and no prior history with the symptom with this car. I wouldn’t think the electrical ignition module, the pick-up coil or O2 sensor could go out just by replacing an Alt. belt. Any thoughts would greatly help.
Find a repair manual for your Nissan Sentra Repair Question.
By Advertisment,
Posted at Tue May 13, 2008 4:44 am
By 2CarPro Jack, Certified ASE Technician
Reputation: 603.5Reputation: 603.5Reputation: 603.5Reputation: 603.5Reputation: 603.5Reputation: 603.5Reputation: 603.5Reputation: 603.5Reputation: 603.5Reputation: 603.5Reputation: 603.5Reputation: 603.5Reputation: 603.5Reputation: 603.5Reputation: 603.5Reputation: 603.5Reputation: 603.5Reputation: 603.5Reputation: 603.5Reputation: 603.5Reputation: 603.5Reputation: 603.5Reputation: 603.5Reputation: 603.5Reputation: 603.5Reputation: 603.5Reputation: 603.5Reputation: 603.5Reputation: 603.5Reputation: 603.5 (603) Give Feedback | Votes: 78
What is the alt output off idle? use your meter to see if it is throwing a/c current, this will mess with the ecm
Posted at Tue May 13, 2008 8:09 am
UPDATE: Prior to receiving this answer I unplugged the neg battery post and also the 02 Sensor and wait a couple of hours, after returning I plug up the neg battery post and started the car, again the 02 Sensor was disconnected. It runs like a champ so I shortly plugged up the 02 Sensor back and still run like a champ. I test drove the car all over then waited till the next morning leaving every thing connected and again no trouble running at all. I am guessing the ECM just needed to be cleared and waiting the few hours with both disconnected done the trick. What are your thoughts? Thanks
Posted at Tue May 13, 2008 2:02 pm
I guess that s possible. needed a little re-learn time
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Popular Question Topics
Alternator
Starter
Exhaust System
Fuel Economy
Rough Idle
Won't Start
Water Pump
Fuel Filter
Battery
Car Alarm
Multi Rib Belt
Catalytic Converter
Head Gasket
Intake Manifold
Motor Oil
Antenna
Air Bag
Fuel Pump
Seat Belts
Heater Core
Air Conditioner
Transmission
CV Axle Joint
Clutch
ABS
Front Brakes
Brake Rotor
Suspension
Oxygen Sensor
Mass Air Flow Sensor
Spark Plugs
Fuel Injector
Check Engine Light
EGR Valve
More Topics...
Popular Manufacturers
ACURA
ASTON MARTIN
AUDI
BMW
BUICK
CADILLAC
CHEVY
CHRYSLER
DODGE
FORD
HONDA
HYUNDAI
ISUZU
JAGUAR
JEEP
LAND ROVER
LINCOLN
MAZDA
MERCEDES BENZ
MERCURY
MITSUBISHI
NISSAN
OLDSMOBILE
PLYMOUTH
PONTIAC
PORSCHE
RENAULT
SAAB
SATURN
SUBARU
SUZUKI
TOYOTA
VOLKSWAGEN
VOLVO
More Manufacturers...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
