Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manuals
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1995 Jeep Cherokee Head...
Auto Repair2003 Chrysler Town And C...
Auto Repair1985 Nissan 300zx High ...
Auto Repair2001 Other Saturn Models...
Auto Repair2005 Nissan Xterra Fuel...
Auto Repair1984 Ford F150 Transmis...
Auto Repair2004 Honda Pilot Window...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1995 Nissan Pathfinder Catalytic Converter
Welcome to our question and answer forum. We answer over 6,000 free and donated auto repair questions every month. All you have to do to ask a question is to signup to our forum.
Asking a question is free of charge and your question will be answered by one of our non-certified forum users for free. You can however elect to donate to make sure your question gets an guaranteed and professional answer by one of our many 2carpros certified repair technicians.
Questions with donations are answered as promptly as possible. Due to the nature of car repair problems, some take longer to solve than others. We are confident that you will be better informed regarding your problem and will have an good idea of what direction your repair needs to go after we have answered it. If you have donated and were unsatisfied with our effort we will gladly return your donation. We help thousands of people every month and want to help you too. Sometimes it requires some dialog between our technicians and you to get to the bottom of your problem. 100% of the donation is awarded to the technicians helping you.
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Thu Jun 26, 2008 5:41 pm
By bearhunter57, New to the forum
Give Feedback | Votes: 0
Engine Performance problem
1995 Nissan Pathfinder 6 cyl Four Wheel Drive Manual 70,000 miles
Why is ithe catayltic converter glowing red?
Find diagnostic tools, replacement parts or locate a car repair manual for your Nissan Pathfinder Repair Question.
By Advertisment,
Posted at Thu Jun 26, 2008 6:20 pm
By rasmataz, Certified 2CarPros Master Technician
Reputation: 952.7Reputation: 952.7Reputation: 952.7Reputation: 952.7Reputation: 952.7Reputation: 952.7Reputation: 952.7Reputation: 952.7Reputation: 952.7Reputation: 952.7Reputation: 952.7Reputation: 952.7Reputation: 952.7Reputation: 952.7Reputation: 952.7Reputation: 952.7Reputation: 952.7Reputation: 952.7Reputation: 952.7Reputation: 952.7Reputation: 952.7Reputation: 952.7Reputation: 952.7Reputation: 952.7Reputation: 952.7Reputation: 952.7Reputation: 952.7Reputation: 952.7Reputation: 952.7Reputation: 952.7Reputation: 952.7Reputation: 952.7Reputation: 952.7Reputation: 952.7Reputation: 952.7Reputation: 952.7Reputation: 952.7Reputation: 952.7Reputation: 952.7Reputation: 952.7Reputation: 952.7Reputation: 952.7Reputation: 952.7Reputation: 952.7Reputation: 952.7Reputation: 952.7Reputation: 952.7Reputation: 952.7 (953) Give Feedback | Votes: 75
When was the last major tune-up
Causes Of Converter Failures
Fouling, clogging, melt-down and breakage of the ceramic substrate inside a converter are common conditions that can cause problems. Plugging is usually the end result of a melt-down, which occurs because the converter gets too hot. This happens because the engine is dumping unburned fuel into the exhaust. The excess fuel lights off inside the converter and sends temperatures soaring. If it gets hot enough, the ceramic substrate that carries the catalyst melts.
The unburned fuel may be getting into the exhaust because of a bad spark plug or valve, but an overly rich air/fuel mixture is another possibility. In older carbureted engines, a heavy or misadjusted carburetor float may be the underlying cause. But on newer engines with "feedback" carburetion or electronic fuel injection, the engine may not be going into "closed loop" (the normal mode where the computer regulates the air/fuel mixture to minimize emissions).
A bad oxygen sensor or coolant sensor may be giving the computer bogus information. A sluggish or dead O2 sensor will make the computer think the exhaust is running lean, so the computer will try to compensate by making the fuel mixture rich. A coolant sensor that always indicates a cold engine will also keep the system in open loop, which means a steady diet of excess fuel. But it might not be the sensor’s fault. A thermostat that’s stuck open or is too cold for the application can prevent the engine from reaching its normal operating temperature. So if your converter has failed and needs to be replaced, the engine should be diagnosed for any underlying problems before the new converter is installed.
Another cause of converter clogging and contamination is excessive oil consumption. Worn valve guides or seals can allow oil to be sucked into the engine’s combustion chambers. The same goes for worn or damaged rings or cylinders. Oil can form a great deal of carbon, and metals present in the oil can contaminate the catalyst. A compression check or leak-down test will tell you if the rings are leaking, while a fluttering vacuum gauge needle will help you identify worn valve guides.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
