Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Cooling problem
1995 Nissan Maxima 6 cyl Front Wheel Drive Automatic 143000 miles
my radiator fan wont go off when the car is idling....when u first crank it up...it warms up normal, the fan will come on and off like norm for a few mins...but if leave it idling for about 20mins i notice the fan dont go off at all...i know this is not normal because it use to go on and off beofore i replace the engine. also i notice it idle about 1000rpm, is that the norm for a 95 maxima?. Another issue im having is i think i have a gas leak...when i first replace the engine, i drove it for about 10miles and the engine light came on...had it check and it was cyl 2 was misfiring....took it back to the mechanic and he replace the injectors with the ones on the old engine...the light hasn't come back on...but now i smell gas when it idle, and at time it idle irregular. i kno its a bad gas leak cause the mileage im getting now is really bad. plus the strong rich smell. we look for physical signs of leaks but could not see any. what could be cause this leak and how can i find it??
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
