Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Manual Ask a Car Repair Question
Auto Repair Manual Car Questions by Manufacturer
Auto Repair Talk Auto Questions by Topic
Vehicle Repair Car Repair Forum
Auto Repair Talk Car Repair Troubleshooting
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Video Series
Vehicle Repair How to Use Test Equipment
Auto Repair Manual Car Maintenance Information
Vehicle Repair Service Engine Soon Light
Vehicle Repair Car Parts and Equipment Store
Vehicle Repair How Does it Work?
Vehicle Repair Safety Inspection
Auto Repair Manual Online Car Repair Manual
Vehicle Repair Smog Test Preparation
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair1989 Plymouth Acclaim S...
Auto Repair2002 Ford Ranger Interi...
Auto Repair2002 Isuzu Rodeo Questio...
Auto Repair1996 Buick Riviera Wate...
Auto Repair1988 Plymouth Voyager T...
Auto Repair1992 Subaru Legacy Engi...
Auto Repair1992 Honda Accord Somet...
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Car Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1995 Lincoln Continental Car won't start unless fuel in thr
Welcome to our question and answer forum where over 6,000 free auto repair questions are answered every month, after you have completed our free signup you will able to ask a question and receive an answer from one of our many forum members.
If you elect to donate any small amount of money we will assign one of our 2CarPros Certified Repair Technicians to answer your question. Questions with donations are answered promptly and 100% of the donation is awarded to the technician helping you.
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Sun Jul 06, 2008 2:17 pm
By asully1979, Have Donated
(6) Give Feedback | Votes: 0
Engine Mechanical problem
1995 Lincoln Continental V8 Front Wheel Drive Automatic 190000 miles
Two days ago I was driving down the road and out of nowhere, my car completely shut off. I put it in neutral while coasting and turned off the ignition & restarted it as if I was restarting it again. It started running again but it did this every 2-3 miles. The next day I tried starting it and it would just rotate, but not fully crank. I've looked online at multiple causes and I actually replaced my coils, I checked to see if I had gas pressure from the valve that is on the fuel rail that supplies the fuel injectors & gas spewed out when wife turned on the ignition when pressing on the release valve so I'm assuming I have pressure. I was also told that I may have bad gas seeing how I put gas in it about 10 minutes before this all started. They said it might have been contaminated with E-85 so I emptied the entire tank out and replaced the fuel and still have no luck getting it started. Then finally I took off the air breather to the throttle body, poured gas down in there, turned the car over & it rain briefly until that gas burned up. And if I keep pouring gas down the throttle body, it will continue to run until that gas has burned up. Also, when I put pour gas down the throttle body and step on the throttle peddle, nothing happens like extra gas getting inside the engine to keep it running... kinda like maybe my injectors aren't getting signal to open? Please help! I'm completely clueless!
Find diagnostic tools, replacement parts or locate a car repair manual for your Lincoln Continental Repair Question.
By Advertisment,
Posted at Sun Jul 06, 2008 2:50 pm
By merlin2021, Certified 2CarPros Master Technician
Reputation: 599.7Reputation: 599.7Reputation: 599.7Reputation: 599.7Reputation: 599.7Reputation: 599.7Reputation: 599.7Reputation: 599.7Reputation: 599.7Reputation: 599.7Reputation: 599.7Reputation: 599.7Reputation: 599.7Reputation: 599.7Reputation: 599.7Reputation: 599.7Reputation: 599.7Reputation: 599.7Reputation: 599.7Reputation: 599.7Reputation: 599.7Reputation: 599.7Reputation: 599.7Reputation: 599.7Reputation: 599.7Reputation: 599.7Reputation: 599.7Reputation: 599.7Reputation: 599.7Reputation: 599.7 (600) Give Feedback | Votes: 48
Use a noid light , unplug the injectors and plug in the noid light, crank engine, does the light flash? Next open the trunck and check the inertia switch, this shuts down the fuel in the event of a crash, but can be tripped or defective, press the button down and recheck for fuel.
http://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Go here and checkout our video. Autozone will rent you the gauge.
Posted at Sun Jul 06, 2008 3:26 pm
Ihave checked the trunck switch and its all the way down so im assuming its reset if it popped and the noid switch can i get one at an auto part store ad where do i find that conector on the pictures to put the noid switch
Posted at Sun Jul 06, 2008 4:32 pm
Hey its me again someone told me i can take a papercliip and clip it on a test light and make the same thing so i did and put the clip on clipside of the testlight and put the probe on red wire side of injector switch wires and there was no flashing or light of any kind when my wife was turning it over
Posted at Sun Jul 06, 2008 4:41 pm
OK check for power at th Batt(=) of the coil pack, if no power, you'll need to start testing the crank sensor, then the CCRM(Contant control relay mpodule) It supplies power via the EEC-V relay inside it to the ignition. The ignition switch itself can also be the problem, turning the key is what triggers the injectors...
Posted at Sun Jul 06, 2008 4:51 pm
what do you mean batt(=) coil pack where the plug wires come from coil paks are brand new and i get spark but if im missunderstanding please let me know my family needs this car bad
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
