Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Manual Ask a Car Repair Question
Auto Repair Manual Car Questions by Manufacturer
Auto Repair Talk Auto Questions by Topic
Vehicle Repair Car Repair Forum
Auto Repair Talk Car Repair Troubleshooting
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Video Series
Vehicle Repair How to Use Test Equipment
Auto Repair Manual Car Maintenance Information
Vehicle Repair Service Engine Soon Light
Vehicle Repair Car Parts and Equipment Store
Vehicle Repair How Does it Work?
Vehicle Repair Safety Inspection
Auto Repair Manual Online Car Repair Manual
Vehicle Repair Smog Test Preparation
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair2005 Kia Spectra Electr...
Auto Repair1996 Nissan Maxima Stalls
Auto Repair2005 Chevy Lumina Hi
Auto Repair1988 Chevy Blazer
Auto Repair2001 Saab 9-3 Repair Que...
Auto Repair1992 Volvo 940 Pcv Oil ...
Auto Repair1992 Nissan Maxima All ...
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Car Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1995 Jeep Wrangler Oil pressure
Welcome to our question and answer forum where over 6,000 free auto repair questions are answered every month, after you have completed our free signup you will able to ask a question and receive an answer from one of our many forum members.
If you elect to donate any small amount of money we will assign one of our 2CarPros Certified Repair Technicians to answer your question. Questions with donations are answered promptly and 100% of the donation is awarded to the technician helping you.
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Sun Jul 06, 2008 9:10 am
By handyken, New to the forum
Give Feedback | Votes: 0
Engine Mechanical problem
1995 Jeep Wrangler 4 cyl Four Wheel Drive Manual 187,65 miles
I have noticed recently that I have been having erratic readings on my oil pressure gauge. It has been reading between 50 and then over 80. I have checked my oil and its fine, and I have changed it recently also. I am guessing I need to change the oil pressure sender. I am not sure where it located on the engine. I could use some advice please.
I also have a lifter noise that I have been dealing with since I had the engine re-built, almost 100,000 miles ago. They told me at the shop that they could not adjust hydraulic lifters. I have a friend of mine that took a look at my top part of the engine to see if every thing was tight, and it was. He thought I had a bad lifter. Do you have any advice for this problem.
thanks
Find diagnostic tools, replacement parts or locate a car repair manual for your Jeep Wrangler Repair Question.
By Advertisment,
Posted at Sun Jul 06, 2008 10:08 am
By rasmataz, Certified 2CarPros Master Technician
Reputation: 839.9Reputation: 839.9Reputation: 839.9Reputation: 839.9Reputation: 839.9Reputation: 839.9Reputation: 839.9Reputation: 839.9Reputation: 839.9Reputation: 839.9Reputation: 839.9Reputation: 839.9Reputation: 839.9Reputation: 839.9Reputation: 839.9Reputation: 839.9Reputation: 839.9Reputation: 839.9Reputation: 839.9Reputation: 839.9Reputation: 839.9Reputation: 839.9Reputation: 839.9Reputation: 839.9Reputation: 839.9Reputation: 839.9Reputation: 839.9Reputation: 839.9Reputation: 839.9Reputation: 839.9Reputation: 839.9Reputation: 839.9Reputation: 839.9Reputation: 839.9Reputation: 839.9Reputation: 839.9Reputation: 839.9Reputation: 839.9Reputation: 839.9Reputation: 839.9Reputation: 839.9Reputation: 839.9 (840) Give Feedback | Votes: 71
Check the oil pressure with a mechanical gauge-if normal replace the oil pressure sending unit if abnormal could be the oil pump pressure relief valve sticking/engine bearings/etc-
Posted at Sun Jul 06, 2008 2:11 pm
By Brewer, Tech level 1
agree with the first poster - use a manual gauge to verify the sender / pressure.
as for the ticking... blame Jeep - they designed a poor engine that requires too much tlc to keep it from ticking. The Hydraulic lifters are not adjustable, but they are very easy to swap out. At $4 each, changing out all of them is cheap. All you need to do is have the right know how.
For the record, many people tell you to buy a specific Hydraulic Valve lifter remover - which can run you anywhere from $20 - $40. In reality, the engine is designed in such a way that you can actually use a telescoping magnet down the push rod hole and bring the lifter out without using a special tool.
I should caution however, changing out the lifters means things won't mesh the same as the originals as far as wear patterns etc go on the camshaft. Should you change just the lifters, you may actually be setting yourself up for more issues too - depending on the severity of the wear on the ones you pulled out. If possible - use a micrometer to verify how close the originals are versus the new ones before you swap. Tedious yes, but could save you a headache too.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
