Engine Performance problem
1995 Isuzu Rodeo Question 6 cyl Two Wheel Drive Automatic 170000 miles
Just got new radiator - mechanic didn't tighten hose and car overheated on way home. Mechanic fixed hose, but now when I start the car in the a.m. white smoke comes from the exhaust. I think head gasket or leaks are present from overheating - does this make sense and if so, should I contact mechanic to fix problem since it is probably a result of his work.
Thanks,
LBC
