Welcome to our question and answer forum. We answer over
6,000 free and donated auto repair questions every
month. All you have to do to ask a question is to signup
to our forum.
Asking a question is free of charge and your question
will be answered by one of our non-certified forum users
for free. You can however elect to donate to make sure
your question gets an guaranteed and professional answer
by one of our many 2carpros certified repair
technicians.
Questions
with donations are answered as promptly as possible.
Due to the nature of car repair problems, some take
longer to solve than others. We are confident that you
will be better informed regarding your problem and will
have an good idea of what direction your repair needs to
go after we have answered it. If you have donated and
were unsatisfied with our effort we will gladly return
your donation. We help thousands of people every month
and want to help you too. Sometimes it requires some
dialog between our technicians and you to get to the
bottom of your problem. 100% of the
donation is awarded to the technicians helping you.
Engine Mechanical problem
1995 Isuzu Rodeo Question 6 cyl Two Wheel Drive Automatic 124000 miles
the water pump wnet out so wechanged it and the timing belt at the same time as recommended...we were careful to make sure that all pulleys and the marks on the timing belt wre aligned as the Haynes manual said to do...the care will crank but it will not start...if we moved a pulley while installing the timing belt can the timing be adjusted or do we have to take the car apart again and start over...or is this not the problem? The car started right up each time before we did the repairs to the water pump and timing belt change...help in Texas!!!
The first thing to do is run a scan and see if you have a set fault code. Check to see if you have spark, injection pulse and fuel pressure as well start here.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
