Posted at Wed May 14, 2008 6:37 pm |
By
JUSTINLOOMIS,
Likes cars! |
Give Feedback | Votes: 0 |
Engine Cooling problem
1995 Honda Prelude 4 cyl Front Wheel Drive Manual 152000 miles
THIS IS A H23A1 ENGINE, JUST REPLACED HEAD , HAD IT SURFACED AND PRESSURE TESTED.THE OLD HEAD TURNED OUT TO BE CRACKED.THIS WAS A SECOND HAND USED HEAD THAT WAS INSTALLED WITH NEW VALVE STEM SEALS, A NEW HEAD GASKET AND WATERPUMP, AND ALL NEW BELTS WERE INSTALLED, AND NEW RADIATOR.THERE WAS NO ANTIFREEZE OR WATER IN OIL, BUT THEIR WAS SOME MILKY OIL STUFF IN THE COOLANT PASSAGES AND RADIATOR.THE CAR FIRED RIGHT UP AFTER INSTALLING EVERYTHING.JUST HAVE A LITTLE TICKING IN TOP END AND WHITE SMOKE COMING OUT MOSTLY WHEN UP TO TEMP.ANY ASSUMPTIONS, PLEASE HELP.I PUT ALOT OF MONEY IN THIS TO GET THIS ISSUE.THANKS
| Find a
repair manual for your Honda Prelude Repair Question. |
By
Advertisment,
| Find a
Posted at Thu May 15, 2008 4:53 am |
By
JUSTINLOOMIS,
Likes cars! |
I CHANGED THE OIL AND IT'S GOOD, AND IT IS NOT LOSING ANY FLUID, BUT I AM DRAINING THE RADIATOR AND REFILLING TO TRY AND GET SOME OF THAT MILKY SHIT OUTTA THEIR, THEIR WAS ALSO SOME OF THAT IN MY INTAKE MANIFOLD AS WELL, I'M WONDERING IF IT JUST NEEDS TO BE RUN TO BURN OFF.
| mhpautos wrote: | Hi there,
Start by changing the engine oil if you have not already done so, and let it run for a while, as it may just be coolant from the previous problem still in the exhaust, this can take a while dissipate sometimes, just keep a check on the coolant level and temp for the first day or so, if the coolant is dropping, you may have a problem still. Start here.
Mark (mhpautos) |
| Find a
Posted at Thu May 15, 2008 8:15 pm |
By
JUSTINLOOMIS,
Likes cars! |
I DROVE IT THE SMORNING VERY LITTLE WITH NO SMOKE BLOWING OUT, TOOK IT FOR A LONGER RIDE EARLYIER, WAS FINE FOR LIKE 5 MIN, THEN STARTED BLOWINGSMOKE OUT AGAIN, GOT TO MY LOCATION AND LET IT RUN FOR ABOUT 20 MIN, GOTT TO BE SOME WHAT DRIVABLE, DROVE IT BACK TO MY HOUSE ABOUT 2.5 MILES AWAY, HALF WAY THEIR STARTED SMOKING AGIAN.... WHAT COULD THIS BE??????
| Find a
Posted at Thu May 15, 2008 8:30 pm |
By
JUSTINLOOMIS,
Likes cars! |
COMPRSESSION TEST OR LEAK DOWN OR PRESSURE TEST RADIATOR??? I DONT THINK IT'S A MANIFOLD ISSUE DO TO OIL IN EXHAUST??? WHY DO YOU THINK THAT??
| Find a
Posted at Fri May 16, 2008 5:43 am |
By
JUSTINLOOMIS,
Likes cars! |
yes the head was presser tested and planned down, the old head was cracked so i got another one.And reassembled it with all new gaskets.the some what milky stuff was still in the block from the old head, but i flushed it out when i put the new head on, plus i got a new radiator and waterpump, and new belts.
| Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
