Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manuals
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1994 Chevy Lumina Ac Ai...
Auto Repair2000 Chevy Lumina Secur...
Auto Repair1995 Chevy Lumina Head ...
Auto Repair1996 Ford Windstar Esti...
Auto Repair1998 Toyota Corolla Lou...
Auto Repair1997 Hyundai Elantra
Auto Repair1997 Chevy Lumina Idle
Auto Repair More Repair Topics...
Site Advertising
Car Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1995 GMC C1500 idle air control
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Mon Jun 02, 2008 9:30 am
By sisneyfamily, Have Donated
Give Feedback | Votes: 0
Electrical problem
1995 GMC C1500 V8 Four Wheel Drive Automatic 131000 miles
my 95 gmc truck will not start sometimes. espically if it is or has rained. i put a code reader on it. it said coolant temp switch and idle air control valve. i put the coolant switch on and it ran for a while. i replaced the iac and now it is back to not starting. i cannot reset the code reader till it starts again of course, i am at a loss. thank you.
Find a car repair manual for your GMC C1500 Repair Question.
By Advertisment,
Posted at Mon Jun 02, 2008 10:25 am
By rasmataz, Certified 2CarPros Master Technician
Reputation: 960.8Reputation: 960.8Reputation: 960.8Reputation: 960.8Reputation: 960.8Reputation: 960.8Reputation: 960.8Reputation: 960.8Reputation: 960.8Reputation: 960.8Reputation: 960.8Reputation: 960.8Reputation: 960.8Reputation: 960.8Reputation: 960.8Reputation: 960.8Reputation: 960.8Reputation: 960.8Reputation: 960.8Reputation: 960.8Reputation: 960.8Reputation: 960.8Reputation: 960.8Reputation: 960.8Reputation: 960.8Reputation: 960.8Reputation: 960.8Reputation: 960.8Reputation: 960.8Reputation: 960.8Reputation: 960.8Reputation: 960.8Reputation: 960.8Reputation: 960.8Reputation: 960.8Reputation: 960.8Reputation: 960.8Reputation: 960.8Reputation: 960.8Reputation: 960.8Reputation: 960.8Reputation: 960.8Reputation: 960.8Reputation: 960.8Reputation: 960.8Reputation: 960.8Reputation: 960.8Reputation: 960.8 (961) Give Feedback | Votes: 75
Other than the coolant temperature sensor/IACV -check the closed/WOT throttle voltages. Did you cleaned the IACV passages-also the CTS hot and cold resistances-
If the engine's condition is in tip top shape-do below to determine if its fuel or spark problem that's if its cranking over and refuses to start
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light.
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems with compression and valves opening and closing at the wrong time
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
