We are the Car Repair Experts!
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1995 Ford Taurus lurching trans on 1995 Taurus SHO
Posted at Fri Nov 06, 2009 6:43 pm |
By
aiger5,
Have Donated |
(23) Give Feedback | Votes: 0 |
Transmission problem
1995 Ford Taurus 6 cyl Front Wheel Drive Automatic 78000 miles
I bought the car used in 2005.Had a lurching transmission problem since.The problem only occurs AS the vehicle reaches temperature,usually as the vehicle shifts from 1st to 2nd, is intermittant and happens only once per drive.Then it shifts normally.Took it to several shops that told me they could find no codes or problem.Trans finally went out in 04/08.Had complete rebuild with torgue converter (AXODE 3196).Unfortunately lurching problem remained.Took it back to the trans shop but was told that there was no problem or codes-probably just me and my wifes imagination!Recently took it to yet another shop ,same blank looks.Today my wife was driving down a grade when lurch occured almost stalling the vehicle.Vehicle drives fine 99% of the time and has no other issues. |
Find a
car repair manual for your Ford Taurus Repair Question.
Posted at Sat Nov 07, 2009 8:24 am |
By
Docfixit,
Certified 2CarPros Master Technician |
         (4956) Give Feedback | Votes: 80 |
Hi
If problem was there after rebuild think PCM maybe the culprit. Shifting is controled by PCM via solenoids. Either solenoids where not replaced or PCM faulty.
Have solenoids been checked and pressure been done?
Let me know
Thanks for donate |
Find a
Posted at Sat Nov 07, 2009 4:46 pm |
By
aiger5,
Have Donated |
No one yet has suggested a problem with the solenoids or PCM.Will call the shop that did the rebuild,but I have a feeling they did as little as possible and probably didnt do a pressure test or check soleniods.Would this be something a regular shop could do or should I look into another trans shop?I think you're right about the soleniods and PCM.I just don't know who to trust with this kind of work.Thanks for the advise. |
Find a
Posted at Sun Nov 08, 2009 11:28 am |
By
Docfixit,
Have had good repair at AAMCO they will test and give estimate |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
