1995 Ford Ranger 1995 Ford Ranger Dome Light Stuck
Welcome to our question and answer forum where over 6,000
free auto repair questions are answered every month,
after you have completed our free signup you will able
to ask a question and receive an answer from one of our
many forum members.
If you elect to donate any small amount of money we will
assign one of our 2CarPros Certified Repair
Technicians to answer your question. Questions
with donations are answered promptly and 100% of the
donation is awarded to the technician helping you.
Electrical problem
1995 Ford Ranger 6 cyl Two Wheel Drive Manual 95000 miles
The dome light stays on. It is supposed to turn off shortly after closing the doors or after getting up to about 15 mph. I had to remove the bulbs.
I cannot find a door switch to see if that might be the problem. Usually, there is a small button that will be pushed in by the closed door. There does not appear to be one that I can see.
Can anyone tell me where the switch is or what might be the problem here?
Thanks
the switch is located insiode the door panel, mounted on the door latch. this is very common, try spraying the bjesus out of it with wd40 and open and shut the door a hundered times real fast, this will usually free it up. **its usually the door thats least used, like the passengers side. let me know how you make out
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
