Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Electrical problem
1995 Ford Mustang 6 cyl Two Wheel Drive Automatic 89000 miles
Ok, this one has me confussed hopeing you can help. my mustang will turn over and over wont start, has no fuel problem checked thought that. But when I disconnect the battery for just 1 second and reconnect the battery it will start and runs great. Then when I turn it off and try to start it again it will not start till I disconnect tha battery again and reconnect it. Any sugestions?
Thanks in advance
Tim
If you have the key with a transponder in it, the security system may be at fault, and by removing the cable, it resets. Go to Ford and have the system reprogrammed, will be one hour labor.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
