Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Brakes problem
1995 Ford F350 V8 Two Wheel Drive Automatic
Ford F350 diesel. No brake pressure - the pedal goes to the floor. Have replaced the master cylinder (4 times), have replaced the vacuum booster and have bled the system several times. When the truck is running, no pressure, the pedal goes to the floor. When the truck is off, the pedal is full. Any ideas on what I can do now?
Did you bench bleed the new master? If yes, pinch off the brake hoses, have someone hold light pressure on the pedal, remove the clamps from the hoses, when your pedal drops, look for leaks at that wheel.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
