Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Brakes problem
1995 Ford F350 V8 Two Wheel Drive Manual 261000 miles
same as the fellow with the 1992 , I clamped the front brake lines off and the pedal stays hard, blocked the rear lines off and the pedal stays hard but when front calipers are hooked up and bleed, the pedal eases to the floor. What is wrong?
Did you inspect the rear wheel cylinders if its drum type for leakage and also adjusted properly.
You block the rear there's no pressure at the wheel cylinders-once unblock pressure will go thru with wheel cylinders leaking it will not hold pressure.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
