Engine Mechanical problem
1995 Ford F250 V8 Four Wheel Drive Automatic 169000 miles
My truck will start just fine for about a dozen tries. Then without warning it will just crank and crank. I wait a little while or try several times more and it fires right up and doesn't skip a beat. Lately it has started to die while I'm driving. I pull to the side and it usually fires right up again and runs perfect. Help!
Find a
repair manual for your Ford F250 Repair Question.
Posted at Fri Apr 25, 2008 2:07 pm
By
Advertisment,
Find a
Posted at Fri Apr 25, 2008 2:37 pm
By
blackop555,Certified 2CarPros Master Technician
best thing to do is wait for it to not start and check for spark at all cylinders with a spark plug tester then check the fuel pressure.
there are a bit of things that can cause a problem like this, and some are fuel related, some ignition so the best thing to do is wait and check as i suggested.
Find a
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
