Auto Repair Talk - Ask a Question, Get a Free Answer
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1995 Ford F150 spongy brake peddle on second tap
Posted at Tue Nov 03, 2009 2:33 pm |
By
cellrescue,
Have Donated |
Give Feedback | Votes: 0 |
Brakes problem
1995 Ford F150 6 cyl Two Wheel Drive Manual 106000 miles
I have a 1995 f150 and when applying the brakes the initial depression is solid however if you are to let up on the pressure and reapply the peddle will travel close to the floor before building pressure. Once the brakes have been released and the vehicle is moving again normal pressure returns for the next initial depression.
The master cylinder and booster were replaced 20,000 miles ago at the dealer and the pads have 25% left on them
I would appreciate any thoughts.
Thanks |
Find a
car repair manual for your Ford F150 Repair Question.
Posted at Tue Nov 03, 2009 7:20 pm |
By
Jacobandnickolas,
Certified 2CarPros Master Technician |
        (8952) Give Feedback | Votes: 70 |
THat is the opposite of everything I have experienced. Have you checked the rear brakes to make sure they are properly adjusted or does it have rear disc? Also, when you release the brakes the first time, does it seem that any of the brakes may be sticking? Try this. Raise one wheel at a time (Safely) spin the tire and have a helper hit the brakes to see if they all release as soon as the brakes are released.
Let me know. |
Find a
Posted at Sat Nov 07, 2009 7:07 am |
By
cellrescue,
Have Donated |
they grab and release fine and are not leaking |
Find a
Posted at Sat Nov 07, 2009 8:48 pm |
By
Jacobandnickolas,
Even though the master cylender was replaced 20K ago, that is the last thing left. |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
