Drive Train Axles Bearings problem
1995 Ford F150 V8 Two Wheel Drive Automatic 170000 miles
i drive a 95 f-150 and my gears have been ate down.i took the rear cover off disconnected the drive shaft from the yolk.then took the 2 c-clips out and the four bolts with brackets that hold the bearings and whole gear in.took the tires and wheels off and the rear drum's and thats it.but the axles still wont slide out wut do i do.
