Car Repair Forum - Ask a Question, Get a FREE Answer.
Go Back
1995 Ford Explorer Wont Start
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Posted at Wed Aug 27, 2008 3:10 pm |
By
phntmfoot,
Likes cars! |
Give Feedback | Votes: 0 |
Engine Mechanical problem
1995 Ford Explorer 6 cyl Four Wheel Drive Automatic 148000 miles
When I turn the key on my truck, the fuel pump kicks on but never shuts off and doesnt start the vehicle. Per some obviously bad advice, I replaced the fuel pump. (after the fuel filter) I keep being told about a green fuel relay that could be the problem but cant find it to save my life. When the problem first came up i could shake the truck and get the fuel pump to turn off and the car could start. Not that little trick doesnt even work. Also, it will start if I spray carb cleaner into the intake but ionly until it burns that off. Thanks for your help.
| Find a
car repair manual for your Ford Explorer Repair Question. |
Posted at Wed Aug 27, 2008 3:43 pm |
By
phntmfoot,
Likes cars! |
The problem is that the fuel pump continues to run while the key is on. it turns off if the key is off.
| Find a
Posted at Wed Aug 27, 2008 4:19 pm |
By
phntmfoot,
Likes cars! |
i swapped it with an identical relay but it does the same thing. other forums keep mentioning a green fuel pump relay but i dont see it anywhere.
| Find a
Posted at Wed Aug 27, 2008 4:46 pm |
By
phntmfoot,
Likes cars! |
inertia switch is not tripped. how would i go about checking the pcm?
| Find a
Posted at Wed Aug 27, 2008 4:54 pm |
By
phntmfoot,
Likes cars! |
i switched the fuel pump relay to the pcm power relay as they are the same part number to no benefit. despite my best efforts, i foresee this one ending up at the shop.
| Find a
Goto page 1, 2, 3 Next
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
