Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Air Conditioning problem
1995 Ford Contour 4 cyl 175,00 miles
I have a 95 Ford Contuor that The compressor on the air conditioning will turn for 1 second and stop fpr 5 seconds continously without ever putting out any cold air> Any insight on this would be so greatly appreciated. Thank you in advance!
I had to look it up and see what this thing looks like and I did find a photo. There is something similar that is on the drivers side by the battery but I don't see a switch I see something plugged into the middle of the cannister. How would someone go about checking to see if the switch is bad and where is it located? Thanks so much!
Unplug it and use a wire to jump across the two leads, if the compressor stays on change the switch, and that is what it's called! low pressure cycling switxh.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
