1995 Ford Aerostar What is wrong with my air conditioner?
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Air Conditioning problem
1995 Ford Aerostar 6 cyl Four Wheel Drive Automatic 150000 miles
When I turn my a/c on in my 1995 Ford Aerostar van it blows warm air. I re-charged my a/c system, and still have the same problem. The belt will click in and shut off every couple of seconds. What could be wrong with my a/c?
The kicking in and out ever few seconds usually indicates low freon. When you recharged it did you check for leaks? If not your local auto parts store should have a can you can buy that is for finding leaks all you will need is a black light to find the leak or leaks.
Also check the Low Pressure switch that is located on the accumulator. Unplug the harness jump the terminals if clutch stays engaged few a while replace switch.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
