Electrical problem
1995 Ford Aerostar 6 cyl Two Wheel Drive Automatic 240,00 miles
The power window on the passenger side works only one direction. It also works only with the switch on the passenger side. My voltage test light shows power when depressing the switch on the drivers side. However the window does not move when using the driver's side switch. I have replaced the switch on the driver's side. However I can not locate a switch for the passenger side. Parts stores say it is unavailable. Do you have any ideas?
