Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1996 Toyota Camry Fans ...
Auto Repair2003 Cadillac Cts
Auto Repair1993 Acura Legend Brake...
Auto Repair2002 Vauxhall Vectra Cl...
Auto Repair2003 Dodge Caravan Car ...
Auto Repair2005 Chevy Malibu Power...
Auto Repair2004 Jeep Laredo High P...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1995 Ford Aerostar oil pan removal
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Sun Aug 24, 2008 4:40 am
By jimmyjoe, New to the forum
Give Feedback | Votes: 0
Engine Mechanical problem
1995 Ford Aerostar 6 cyl Two Wheel Drive Automatic 160.00 miles
raising the motor does not let you drop the pan, whats the secret???
Find a car repair manual for your Ford Aerostar Repair Question.
Posted at Sun Aug 24, 2008 4:46 am
By merlin2021, Certified 2CarPros Master Technician
Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1 (633) Give Feedback | Votes: 51
3.0 or 4.0?
OIL PAN Removal 1. Disconnect negative battery cable. Raise and support vehicle. Remove starter. Remove transmission. For M/T models, see appropriate article in CLUTCHES. For A/T models, see TRANSMISSION REMOVAL & INSTALLATION article in TRANSMISSION SERVICING. 2. On 4WD models, remove front wheels. Remove pivot bolts/nuts from lower control arms, and allow control arms to hang free. Position jacks under control arms and then remove pivot bolts. Remove lower control arm rear pivot bracket from crossmember. Remove front drive axle assembly mounting bolts, and wire aside. See appropriate article in SUSPENSION. 3. On all models, drain engine oil and remove oil filter. Disconnect low oil level sensor connector from engine oil pan. Remove 2 engine-to-transmission bolts and spacers. Remove oil pan retaining bolts/nuts. On 4WD models, raise engine approximately one inch (25 mm). On all models, remove oil pan. Remove oil pan gasket and crankshaft rear main bearing cap and wedge seal. See Fig. 9 . Fig. 9: Exploded View Of Oil Pan Assembly Courtesy of FORD MOTOR CO. Installation 1. Clean gasket mating surfaces. Apply small amount of silicone sealer to engine block, where oil pan, rear seal and block mate. See Fig. 9 . 2. Install NEW crankshaft rear main bearing cap wedge seal. Wedge seal should fit snugly into sides of rear main bearing cap. See Fig. 9 . Position NEW oil pan gasket into groove in oil pan. If installi ng original oil pan, go to step 5). If installing NEW oil pan, go to next step. 3. If transmission is still in vehicle, position oil pan on engine without spacers. Install oil pan retaining nuts on 4 locating studs. Using a feeler gauge, measure gap between locating pads on oil pan and transmission bellhousing. 4. If transmission is removed from vehicle, position oil pan on engine without spacers. Install oil pan retaining nuts on 4 locating studs. Place a straightedge across mounting surface on back of engine, and measure difference between mounting surface on engine and mounting surface on oil pan. See Fig. 10 . Determine spacer thicknes s from measured clearance. See SPACER SELECTION table. Remove oil pan, and go to next step.
CAUTION: If installing original oil pan, existing oil pan spacers may be used. If installing NEW oil pan, measure oil pan-to- transmission clearance and install correct spacers to prevent oil pan damage and/or oil leaks. 5. Position oil pan spacers on oil pan locating pads. Install oil pan. Tighten retaining bolts/nuts tight enough to compress oil pan gasket so transmission bolts align with holes in oil pan, but loose enough to allow oil pan to move when transmission bolts are installed. 6. Install oil pan-to-transmission bolts and tighten to specification. Install and tighten all oil pan bolts to specification. See TORQUE SPECIFICATIONS . To complete installation, reverse removal procedure. Fill or top off fluids. Start engine and check for leaks.
This is 4.0 instructions!
Page 1 of 2 4.0L V6 - VIN [X] -1995 Ford Aerostar
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
