Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manuals
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1989 Chevy Suburban Spu...
Auto Repair1995 Chevy Lumina Volta...
Auto Repair1988 Buick Century Cran...
Auto Repair2002 Ford Taurus Removi...
Auto Repair1995 Mazda Truck Fuel S...
Auto Repair2002 Ford Explorer Emer...
Auto Repair2001 Chrysler Grand Voya...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1995 Dodge Dakota Dropps dead after 20 min
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Wed Apr 16, 2008 4:46 pm
By stuckchuck, Likes cars!
Give Feedback | Votes: 0
Electrical problem
1995 Dodge Dakota 6 cyl Two Wheel Drive Automatic 150000 miles
Ok truck belongs to my mother who beleives in only putting gas in a car. Enough said about prior maint. Car came to me after 3rd break down to "get it running" It will start when cold and run fine for about 20-30 min then its like someone just cuts off the fire to the engine. All other electrical function is fine pleny of juice plenty of crank no go.
Checked codes popped for bad coil/Distributor
Installed new coil new pick up new button and cap
put in new plugs and wires (did an oil and all filter change while i was there) Also I jockeyed the main relays around (all same part #) and verified my fuses.
Test drive .......Walk home
I can return to the car about 4 hours later and it will start and drive home. I have replaced everything up to the ECM but before I bit the big bullet I wanted to know if there was anything else I am missing. Is there a sensor that if hot or bad could tell the ECM to kill ignition??
Other info I think my Cad converter is bad and have a replacement that I have not cut in yet (along with new muffler) Also I noticed a small leak at the water pump which might be going out but gauge has never shown hot and I have checked for water flow its flowing when Tstat changes.
All help greatly appreciated pulling my hair out here
Sign me
Stuck
Find a car repair manual for your Dodge Dakota Repair Question.
By Advertisment,
Posted at Wed Apr 16, 2008 5:59 pm
By BMRFIXIT, Tech level 10
Reputation: 465.4Reputation: 465.4Reputation: 465.4Reputation: 465.4Reputation: 465.4Reputation: 465.4Reputation: 465.4Reputation: 465.4Reputation: 465.4Reputation: 465.4Reputation: 465.4Reputation: 465.4Reputation: 465.4Reputation: 465.4Reputation: 465.4Reputation: 465.4Reputation: 465.4Reputation: 465.4Reputation: 465.4Reputation: 465.4Reputation: 465.4Reputation: 465.4Reputation: 465.4 (465) Give Feedback | Votes: 16
Did you check or replaced the crank position sensor
its rear right of the engine
Crank sensor failure describe your condition
I suggest if you haven’t check or replaced it
to do so
good luck
Posted at Wed Apr 16, 2008 6:14 pm
Well I am not firmilliar with this sensor but I will find it and check it I just got it restarted and into the garage (from about 2 miles up the street 3 hours ago) but I will scope it again tommorrow afternoon and look for that sensor. If you could please describe what that sensor ...sences?? and would it cause a code to pop if it was bad
Thanks for your help and patience
Stuck
Posted at Wed Apr 16, 2008 6:32 pm
I would ask the part store to show me the sensor and or you can buy new one so u can see what does it look like
the crank position sensor give the signal to the computer who ground the ASD relay which supply volts to coils allowing it to fire
as for the sensor under the cap its to synchronize the injectors
moving the distributor will not effect timing because computer get the signal for the crank sensor
good luck
Posted at Wed Apr 16, 2008 6:46 pm
I will look into that first thing after work
I would also like to thank you for your fast responces I was taking shots in the dark after the "tune up" failed My father in law wants to try a new ECM but I was hoping for a less drastic repair.
I will try the sensor and let you know thanks again for quick responce
Stuck
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
