1995 Dodge Caravan Timing chain/ set
Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Manual Ask a Car Repair Question
Auto Repair Manual Car Questions by Manufacturer
Auto Repair Talk Auto Questions by Topic
Vehicle Repair Car Repair Forum
Auto Repair Talk Repair Troubleshooting
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Video Series
Vehicle Repair How Does it Work?
Auto Repair Manual Car Maintenance
Vehicle Repair Online Repair Manual
Vehicle Repair Auto Parts
Vehicle Repair Safety Inspection
Vehicle Repair Smog Test
Auto Repair Manual Diagnostic Trouble Codes
Vehicle Repair Engine Code Scanner
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair2006 Mazda Tribute Powe...
Auto Repair2000 Pontiac Bonneville ...
Auto Repair1997 Ford F150 Ignition...
Auto Repair2002 Toyota Camry Drain...
Auto Repair1998 Other Nissan Models...
Auto Repair1994 Ford Escort No Lig...
Auto Repair1995 Dodge Neon Wont Start
Auto Repair1999 Ford Crown Victoria...
Auto Repair1998 Toyota Camry Overh...
Auto Repair2001 Cadillac Catera Va...
Auto Repair2001 Honda Civic Check ...
Auto Repair1991 Chevy Silverado En...
Auto Repair2001 Gmc Savana Rear Br...
Auto Repair1996 Dodge Neon How To ...
Auto Repair1997 Hyundai Sonata Iat...
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Other Websites
Auto Repair Computer Repair Questions
Auto Repair Search Engine Optimization
Auto Repair WhyOurWorld.com
Auto Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
Welcome to our question and answer forum were over 6,000 free auto repair questions are answered every month, after you have completed our free signup you will able to ask a question and receive an answer from one of our many forum members.
If you elect to donate any small amount of money we will assign one of our 2CarPros Certified Repair Technicians to answer your question. Questions with donations are answered promptly and 100% of the donation is awarded to the technician helping you.
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Sat May 10, 2008 11:04 pm
By fearl, New to the forum
Give Feedback | Votes: 0
Engine Mechanical problem
1995 Dodge Caravan 6 cyl Two Wheel Drive Automatic
When should sprockets/ chain be changed?
Find a repair manual for your Dodge Caravan Repair Question.
By Advertisment,
Posted at Sat May 10, 2008 11:31 pm
By Rob2008, Tech level 2
Here are four ways to check a timing chain for excessive stretch:
1. On engines without chain tensioners that have distributors driven by the camshaft, watch the timing mark while checking ignition timing at idle. If the mark moves back and forth, the chain is loose.
2. To check a pushrod engine for chain slack while the engine is in the car:
* Remove the distributor cap and turn the vibration damper in one direction until the distributor rotor begins to turn.
* Then, turn the crank in the opposite direction until the rotor moves again.
* Observe how far the damper moves before the rotor turns.
o Because most distributors are driven by the cam, this is a good way to check for chain slack on these engines.
The engine may still run acceptably with 10° to 15° of chain slack. But ideally, movement should be less than 5° at the crank.
3. To check for a stretched roller chain, pull on the top of the chain while it is on the same sprocket. This can be done during a valve adjustment, while the valve cover is off. A worn chain will have considerable slack when tested in this manner; a new chain will fit snugly on the sprocket.
4. The most obvious way to check chain slack is to measure the slack during engine disassembly, after removing the timing cover.
* Be sure to turn the crank in one direction first, in order to tighten up one side of the chain.
* Then measure the amount of slack in the chain.
-Rob
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
