Car Repair Forum - Ask a Question, Get a Free Answer
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1995 Dodge Avenger 95 dodge avenger starting and idleing is
Posted at Sat Nov 07, 2009 11:21 am |
By
jhensche@hotmail.com,
Have Donated |
Give Feedback | Votes: 0 |
Engine Performance problem
1995 Dodge Avenger 4 cyl Front Wheel Drive Manual 200000 miles
My avenger with a 2.0 4cyl. has had some problems starting and then idleing. This occurs when the car is ether cold and or warm. Upon the first crank the car fires and revs to 1300 rpm, runs for 3-5 sec. then sounds as if it floods out. Re-cranking, the engine will spit and sputter for several cranks (2-3) then finally start and spit and sputter as if flooding out. There is no tell tale of unburned fuel out of the exhaust. It will idle good for 5 minutes then idle rough. If it is reved up then run fine. It does have some hesitation at low rpm while driving, typically around 1000-1700 rpm. Could this be the fuel pressure regulator or possible a fuel injector issue? I have recently replace the throttle position sensor. The car has a recent tune up new plugs wires and oil change. Although not the fuel filter, also no leaks for any kind. |
Find a
car repair manual for your Dodge Avenger Repair Question.
Posted at Sat Nov 07, 2009 5:51 pm |
By
mathiaso,
Certified 2CarPros Technician |
  (318) Give Feedback | Votes: 14 |
the unburn fuel from the exhaust show that the fuel pump and regulator are ok
the problem is that there is no spark.
remove spark plug and find out witch one is not firing(the wet one)
you may have engine light, if so have it diagnose for code and come back |
Find a
Posted at Sat Nov 07, 2009 8:31 pm |
By
Have Donated |
Thanks guys,
However, as I stated there is no sign of unburned or raw fuel in the exhaust. AKA no raw fuel smell coming from the exhaust. The spark issue bring up another question. Could it be a sporadically malfunctioning coil pack? |
Find a
Posted at Sun Nov 08, 2009 12:52 am |
By
mathiaso,
Do you have engine light on?or no code(s)?
without the code(s) we will be guessing.
it could be anything from weak fuel pump,mafunctioning regulator,dirty injectors,coil pack....
come with code(s) we'll help. |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
