Car Repair Advice by Professional Automotive Experts
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1995 Chrysler Intrepid backfire
Posted at Tue Jun 23, 2009 4:45 am |
By
garnzy,
Likes to hang around! |
(25) Give Feedback | Votes: 0 |
Engine Mechanical problem
1995 Chrysler Intrepid 6 cyl Front Wheel Drive Automatic 148000 miles
my chrysler intrepid sometimes backfires and is hard to start.when it is running it sounds pretty Report Spam and drives great.i once pulled out a plug and it appeared to be wet.the plugs are new,coil pak,wires,tps,o2 sensors,idle air control valve ,fuel filter,air filter.does it sound like small injector leakdown.the rest of the cylinders seem fine.even the one that is troublesome plus is burning normal after it has run for a while.It is definitely not the catalytic converter,there were no sensors attached to it.awhile back i had to hold my foot to the floor to start it,like it was flooded.the fuel rail was tested for pressure,but if it is a small crack in the injector i dont think that it woould register on the gauge as being that if the gauge was only on for about 10 minutes.what do you guys think.am i jumping to conclusions.it seems that sometimes also there is a slight pulsing of about 40 rpm difference when idling.thank you so much for the forum guys.youve helped alot of people. |
Find a
car repair manual for your Chrysler Intrepid Repair Question.
Posted at Sat Jul 04, 2009 4:22 am |
By
garnzy,
my suspicion was right,after taking it to the mechanic for the last time i figured i would look at it myself.I bought new injectors and plenum gasket and replaced them.the car runs 100%.the injectors had leakdown,but not enough that it could be seen on a gauge after ten minutes.from now on i will do all of the work on this car as i have done in the past.hope this is helpful to someone else. |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
