We are the Auto Repair Experts!
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1995 Chevy Truck tach and speedo not working,trans not shif
Posted at Sat Sep 12, 2009 5:39 pm |
By
lovepugs4,
New to the forum |
Give Feedback | Votes: 0 |
Electrical problem
1995 Chevy Truck V8 Four Wheel Drive Automatic 191000 miles
my tach and speedo quit,my trans stopped shifting.wiil go into gear forward or rev but seems to be starting out in higher gear and dose not shift.the trans indicater light dose not work.tried new gauge cluster still no change.pluged scanner up it dose read rpms and speed.this all happened at the same time.i am thinking ecm problem?
no fault codes logged
thank you |
Find a
car repair manual for your Chevy Truck Repair Question.
Posted at Wed Sep 16, 2009 2:12 am |
By
lovepugs4,
New to the forum |
nothing is free,i had this question posted for a week and got no help. i fixed this myself.it was my ignition switch it feeds power to the trans fuse in the run position and gages. posted this to help someone else.beware nothing for free |
Find a
Posted at Tue Oct 20, 2009 8:21 am |
By
trapper_canada,
New to the forum |
| lovepugs4 wrote: | | nothing is free,i had this question posted for a week and got no help. i fixed this myself.it was my ignition switch it feeds power to the trans fuse in the run position and gages. posted this to help someone else.beware nothing for free |
Hi there,
Just this morning I believe I had a very similar thing happen. Everything died, engine reved but it was not moving to well. I stopped and turned the truck off then on and the guages came back but tranny was still not right. When I shifted the transmission into 2nd the speedo/tach/gear indicator all died again.
I have an appointment at the shop tonight...I will suggest they consider the ignition switch...although not quite sure if it is the same.
Thanks. |
Find a
Posted at Fri Nov 20, 2009 1:19 pm |
By
tino9,
New to the forum |
There is a little white plastic box located behind the glove box. This unit controls the speedometer in the dash, that might be affecting shifting. Try going to the salvage yard to find a replacement part. |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
