Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2004 Infiniti G35 Repai...
Auto Repair2001 Chevy Blazer Fuel ...
Auto Repair1998 Buick Century Left...
Auto Repair1998 Other Plymouth Mode...
Auto Repair1999 Chevy Venture Over...
Auto Repair1991 Jaguar Xj6 Power S...
Auto Repair1996 Chevy Truck Hot Ma...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1995 Chevy Truck Maintaining Performance
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Fri Jul 25, 2008 5:10 pm
By Cowboy6423, Likes cars!
Give Feedback | Votes: 0
Engine Performance problem
1995 Chevy Truck V8 Four Wheel Drive Automatic 92,000 miles
My truck has some performance products added to it such as: AME cold air intake system, Accel ignition tune-up kit, Hyper-Tech computer chip, street performance throttle body spacer, dual exhaust, and Jet Performance thermosate. Do you recommend using engine flush when changing a trucks oil? Also I put maybe 3000 miles a year on this truck at most, what is the best way to store a vehical to keep it running at its peak performance? Thanks
Find a car repair manual for your Chevy Truck Repair Question.
Posted at Fri Jul 25, 2008 5:32 pm
By mastertechtim, Moderator
Reputation: 302Reputation: 302Reputation: 302Reputation: 302Reputation: 302Reputation: 302Reputation: 302Reputation: 302Reputation: 302Reputation: 302Reputation: 302Reputation: 302Reputation: 302Reputation: 302Reputation: 302 (302) Give Feedback | Votes: 20
for heavens sake no. no engine flush. it can harm engine bearings while it is supposed to be cleaning them. if storing for a long time i would suggest adding stabil fuel stabilizer and change oil before storing so the acid in the old oil wont be sitting on the bearings. disconnect battery and thats it. i have just about the same truck and have all the same add ons you have. if your feeling a little froggy you may want to put on a set of headers for your next project, it so far has made the most improvement on performance. i miss my truck, its been in the body shop for 2 weeks getting repainted and was supposed to be done tonight. seeing your truck has made me a little sad.
Posted at Sat Jul 26, 2008 3:27 pm
I will take that suggestion and will probably be putting headers on within the year. Do you have any that you recommend? Also, I am thinking about just tying them into the duals that I already have. Do I need to worry about any sensor problems? I am also in thinking about putting 4.10 gears in to help with the larger tires that I have. Do you recommend doing this, what should it roughly cost, and also have any recommendations? I was also wondering about Synthetic Oil like AMSOIL what is your opinion. Lastly as far as vehical storage goes I have heard that you should take out the spark plugs and put a little oil in each cylinder then reistall the plugs. Is that a good idea or not nessacery? Thanks again for all the help that you have provided Tim.
Posted at Sat Jul 26, 2008 4:29 pm
i think dynaflow has headers that bolt directly up to the exhaust pipes you already have and no other mods are needed. as for the 4.10, probably the vehicle has 3.73 already and to jump to 4.10 wont really give you any substancial performance and you would also have to change the front diff gears too. my opinion its not worth it. as for putting oil in the cylinders, thats going to the extreme but you could in that case just spray a marine fogging oil into intake when shutting down, this will do the same thing. i got the word that today the truck got painted and looks awesome, but i wont get it back til wednesday due to reinstalling moldings and having it detailed. i will post some pictures when i get it back.
Posted at Sun Jul 27, 2008 6:12 am
I look forward to seeing some pictures of your truck when it is all done. Hope that it turns out the way you want it too. I had another question of course, I tryed calculating my rear end ratio by jacking up one side in the rear and rotating the tire 10 times and counting the number of axel rotaions. The transfer case was in nuetral and I only got 17 to 10 so 1.7 to 1, which cannot be right. Do you need to do something different for rear ends that are not locked to calculate the ratio or is there another way of getting it. It is a GM 10 bolt 8.5". Also how would I find out what transmission I have? I think it is a GM - 4L60E. Would you recommend Synthetic Oil in the transmission, transfer case, and front rear diff. Thanks again for all the advice
Posted at Sun Jul 27, 2008 1:55 pm
easiest way to tell gear ratio and if its posi is to call the dealer with the vin # and they will tell you. synthetic oil in my opinion is over rated.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
