Car Repair Talk - Ask a Question, Get a FREE Answer.
Go Back
1995 Chevy S-10 multifunctual signal switch
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Posted at Wed Jun 11, 2008 2:17 pm |
By
clyde t ottaway,
Have Donated |
(8) Give Feedback | Votes: 0 |
Electrical problem
1995 Chevy S-10 4 cyl Two Wheel Drive Manual 135000 miles
can the male and female push pull plug be replaced indivudally i checked brake switch it's ok what else should i check don't be in a hurry i will be gone for 3days.
| Find a
car repair manual for your Chevy S-10 Repair Question. |
Posted at Sat Jun 14, 2008 12:08 pm |
By
clyde t ottaway,
Have Donated |
You said to check brake light switch and push pull plug on multifunctual switch i assumed you were talking about the signal switch if not please explain.And any other thing i could check to get my brake lights and signal switch working.
| Find a
Posted at Sun Jun 15, 2008 10:56 am |
By
clyde t ottaway,
Have Donated |
Yes but i have replaced the signal switch after i replaced the head i broke the emergency flasher's.i also replaced the wire's to the starter switch.You said to check the push pull plug i assumed that was the plug from the signal switch,if not please explain i am the first to say i am not a qualified mechanic any new ideas are welcome.
| Find a
Posted at Sat Jun 21, 2008 11:44 am |
By
clyde t ottaway,
Have Donated |
the only wire i find is the air bag wire where this small wire run from where does it hook in.
| Find a
Posted at Sun Jun 22, 2008 8:18 am |
By
clyde t ottaway,
Have Donated |
Is the air bag connector the only small connector other tha the plug on the signal switch push pull plug i do not have cruise control.
| Find a
Goto page 1, 2 Next
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
