Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2004 Infiniti G35 Repai...
Auto Repair2001 Chevy Blazer Fuel ...
Auto Repair1998 Buick Century Left...
Auto Repair1998 Other Plymouth Mode...
Auto Repair1999 Chevy Venture Over...
Auto Repair1991 Jaguar Xj6 Power S...
Auto Repair1996 Chevy Truck Hot Ma...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1995 Chevy Lumina GM Engine Moving Tool
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Fri Aug 29, 2008 5:51 am
By Tomd915, Have Donated
Give Feedback | Votes: 0
Engine Mechanical problem
1995 Chevy Lumina 6 cyl Front Wheel Drive Automatic 112K miles
I have a 3.1L V6 and I want to change spark plugs. Its a side-mount engine and I need to get to the plugs back by the firewall.
Ther is a tool made by Thexton - GM engine moving tool - that will replace one of the front torque struts and you can move the engine forward tilting it until you can get to the back plugs. The tool has a steel threaded rod going throught it with a 3/4" bolt end that you turn to move the engine. Yeah right! Let's see if I can get it to move at all, but that is what it's suppose to do.
My question(s) are: 1 - I know I need to put the car in neutral and block the wheels, but the manual I have says to disconnect the Neg. battery terminal. The car has a GM security system of some type. My ignition key has a black plastic square with a metal contact in it for this system.
I am not going to disconnect the battery fearing that I will lock-up this system some how. As far as I know disconnecting the battery is to prevent arching and I've never done it in all of the many years I have changed spark plugs on cars. Will that be Ok? Should I or can I disconnect the battery? It seems like one more step I don't really need to do and it could make problems for me.
My next question is a general one. I know I am suppose to put the car in neutral and block the wheels. If any of you have used a tool like this to tilt the engine forward can you tell me what I should expect? Is there anything else I should look out for? I plan to do this slowly and keep an eye on everything I can.
I really don't want to do this but it seems to be the only way to get to the plugs back by the firewall. I don't have access to a lift or mechanics pit and from what I can see going in from under the car might not work anyway. IOf there is a better way I don't know about please let me know asap. Maybe I missed something.
Find a car repair manual for your Chevy Lumina Repair Question.
Posted at Fri Aug 29, 2008 10:16 am
By blackop555, Certified 2CarPros Master Technician
Reputation: 106.8Reputation: 106.8Reputation: 106.8Reputation: 106.8Reputation: 106.8 (107) Give Feedback | Votes: 27
the tool works good use it, i do that all the time.
You should be able to unhook the battery no problem at all with it, but you dont have too remove the battery.
i recommend doing it when changing the oil though!, they also have thigns that plug in the cigarette lighter that keeps the memory going and is a worthy investment.
once again ill say use the tool.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
