Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manuals
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1989 Chevy Suburban Spu...
Auto Repair1995 Chevy Lumina Volta...
Auto Repair1988 Buick Century Cran...
Auto Repair2002 Ford Taurus Removi...
Auto Repair1995 Mazda Truck Fuel S...
Auto Repair2002 Ford Explorer Emer...
Auto Repair2001 Chrysler Grand Voya...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1995 Chevy Impala Car Starts when cool but dies upon warmin
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Sun Jul 06, 2008 3:18 pm
By cmptrguy1, Have Donated
Give Feedback | Votes: 0
Engine Mechanical problem
1995 Chevy Impala V8 Two Wheel Drive Automatic 72000 miles
1995 Chevy Impala SS 72K miles
Replaced water pump, Opti Spark
Car starts when cool, runs fine for a few minutes until warm then dies, Sometimes I can start it But it will run very rich like it is in WOT Mode Will not idle at all. Let it cool down and it starts fine once again.
Not sure what to look at? Oxygen Sensor, IAC Module, TPS Can any of these cause the engine to just shut off once it warms up?
It is driving me crazy
Thanks
Gary
Find a car repair manual for your Chevy Impala Repair Question.
By Advertisment,
Posted at Sun Jul 06, 2008 3:57 pm
By merlin2021, Certified 2CarPros Master Technician
Reputation: 627.7Reputation: 627.7Reputation: 627.7Reputation: 627.7Reputation: 627.7Reputation: 627.7Reputation: 627.7Reputation: 627.7Reputation: 627.7Reputation: 627.7Reputation: 627.7Reputation: 627.7Reputation: 627.7Reputation: 627.7Reputation: 627.7Reputation: 627.7Reputation: 627.7Reputation: 627.7Reputation: 627.7Reputation: 627.7Reputation: 627.7Reputation: 627.7Reputation: 627.7Reputation: 627.7Reputation: 627.7Reputation: 627.7Reputation: 627.7Reputation: 627.7Reputation: 627.7Reputation: 627.7Reputation: 627.7 (628) Give Feedback | Votes: 50
EGR and 02 sensors are not used until the PCM goes into closed loop, as engine warms up, try unplugging the 02 sensors first, there could be a short in one of em...
Posted at Mon Jul 07, 2008 7:03 am
I will try that this evening.
Just unplug them no need to jumper or anything?
Posted at Mon Jul 07, 2008 4:01 pm
If all is in good order, it will set a trouble code or two, but if it solves the problem, replace the bad part, and it will reset after so many drive cycles.
Posted at Mon Jul 07, 2008 8:09 pm
I pulled the plugs on the O2 Sensors. Started the car it ran for 8 minutes then died. One thing I noticed was that both cooling fans are on from the moment I started the engine. I never noticed this before. is that normal until the PCM goes into full operation or is this an indicator. The Check engine light was on but when I tried to pull the codes I got no error codes. Any other suggestions.
Posted at Tue Jul 08, 2008 3:16 pm
Check the ECT and IAT, if you can read these as degree values, before you start it, they should be within 5 degrees...then use an ohm meter, when cold you should have 10,000 or higher, as it warms up, the resistance drops to 177 when warm. On both sensors. A bad tpr would probably stop you from starting the car, but you can give it a shot..The only fan that should run is the A/C condeser fan when the A/C is on...might want to check in the power distribution center for the fan relays.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
